Dishwasher And Disposal Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 11:01 AM   #1
DIY'er
Rewards Points: 31
Question
Dishwasher and Disposal Wiring
Currently, we are doing a kitchen remodel and I want to move the dishwasher outlet from behind the dishwasher into the sink base. There is a 12/3 circuit that feeds both. Can I just move that line into the disposer gang box and wire the top outlet for the disposer and the bottom outlet for the dishwasher or should they really be in their own gang boxes?
gpraceman is offline   Reply With Quote
Old 05-29-2013, 11:16 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,348
Curiosity, I'm assuming when you say 12/3, this is a MWBC and the DW and disposer are on different legs and maybe even dedicated circuts.
I am uncertain to code, which I believe your question is adressing, but I think that is not prohibited.Although as to splitting the device, I really am uncertain.
This is nothing other than unsubstantiated personal opinion, but I sure like to try and keep that 240 out of the same box, let alone the same device. I just think it can be a problem down the road for a non knowledgeable home owner.(Some homeoner replaces the device down the road and think he has duplicated the wiring, but never broke the tab to split the device and .....wham).
Our requirements for handle ties at the panels , and even tieing the feeds together as the enter the panel, are inexpensive and good code.
We got some really excellent sparkies and electrical men who will I'm sure correct me or confirm code for ya.
Best ...
MTN REMODEL LLC is offline   Reply With Quote
Old 05-29-2013, 11:19 AM   #3
DIY'er
Rewards Points: 31
The dishwasher and disposal each have their own 20A breaker that are tied together. I assume due to their close proximity that they ran a single 12/3 line instead of two 12/2 lines. Red wire powers dishwasher and black wire powers disposal.
Old 05-29-2013, 11:27 AM   #4
Handyman
It sounds as if you are attempting to run two separate lines into one box? If that's the case then just run new lines to separate boxes. That would seem best if all you are trying to do is move an outlet.
nicktools561 is offline   Reply With Quote
Old 05-29-2013, 11:31 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes you can relocate the 12/3 to another box. Cut the brass jumper, leave the neutral jumper in place and install on a 2 pole breaker.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
jbfan (05-29-2013)
Old 05-29-2013, 11:35 AM   #6
Yep....99.99999999% chance you are dead right. And that would be good smart economic wiring.
Do you understand MWBC (multi wire branch circuts).... ya probably do...just checking.
EDIT...Thanks Electures... OP... I guess that is code compliant which I thought... but I personally still don't like it from shearly a belief that MWBC confuse a lot of DIY.
Good luck
Old 05-29-2013, 11:37 AM   #7
DIY'er
Rewards Points: 31
No, it is a single 12/3 line that happens to power the dishwasher and disposer. It runs into the old dishwasher box and then a short 12/2 line runs to the disposer box.
Old 05-29-2013, 11:47 AM   #8
GPRICE.... don't know what it looks like under your sink base.... but would not it be almost easier to drop in a remodel box.... then trying to fish into and stuff an existing box????
Old 05-29-2013, 12:01 PM   #9
DIY'er
Rewards Points: 31
Not really. I just cut an access hole in the drywall below the box so I could drill the hole in the sole plate for the line to come in. That hole gave me easy access to feed the line into the existing disposer box. I'm not too worried about making a bunch of holes in the drywall, since they will be covered up by cabinets.
Thanks for the confirmation. I finished the task and did just that. The breakers are two single poles but they have a metal piece tying them together.
The Following User Says Thank You to gpraceman For This Useful Post:
MTN REMODEL LLC (05-29-2013)
Old 05-29-2013, 01:22 PM   #10
electures's Avatar
The metal piece has to be listed for the application.
Old 05-29-2013, 01:34 PM   #11
DIY'er
Rewards Points: 31
Attached is a photo of the main panel showing the metal clip across the two breakers. The builder did the same setup with the fridge and one of the small appliance circuits.
Old 05-29-2013, 01:49 PM   #12
Oso954's Avatar
Rewards Points: 1,310
I hope that means you are not concerned about having a bunch of patches, rather than you don't plan on patching holes.
Oso954 is offline   Reply With Quote
Old 05-29-2013, 01:53 PM   #13
DIY'er
Rewards Points: 31
I'm not worried about having a bunch of patches.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Wiring garbage disposal and dishwasher? Ebierley Electrical 7 02-14-2013 05:43 PM
Wiring up a dishwasher and disposal lmorsino Electrical 20 02-12-2013 06:41 PM
dishwasher, disposal and OTR Micro circuits rasz Electrical 29 08-24-2011 07:47 PM
