Dishwasher Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2006, 01:03 PM   #1
Rewards Points: 150
dishwasher connection
I have just pulled my 12/2 through the studs for my dedicated 20amp dishwasher circuit. (kitchen remodel)
Do I just pull the wire through a hole in the future drywall, or should it go through a box of some sort?
I don't have a dishwasher yet, but I'm told that they are "hard wired" these days. Thanks.
handifoot is offline   Reply With Quote
Old 05-20-2006, 01:20 PM   #2
Is this circuit connected to the main panel? (is it powered)
I would leave it disconnected from the main until you get the washer.
The wire is hard wired to the lower front of the dishwasher (most of the time) inside a metal enclosure. Leave enough wire to go from the wall to the front of the dishwasher with some to spare.
redline is offline   Reply With Quote
Old 05-20-2006, 05:06 PM   #3
Rewards Points: 150
Of course it's not connected to power yet!!! It won't be until all the final connections are done. All I need to know is if it"s cool to have the Romex just come out through a hole in the drywall
Old 05-20-2006, 06:20 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro electrician, but no.
It should be routed through an electrical box at the wall (probably with a cover on it and conduit to the connection box of the dw). Check with your Building Inspection Department for local code.\
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-20-2006, 07:26 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Yes, it is fine for the NM to poke out of the wall and to the DW. Some areas do require a local disconnect at the unit. This can be a switch, or a receptacle with a cord and plug on the DW itself.
Conduit is only needed if you are in conduit country, such as Chicago.
Old 05-20-2006, 10:18 PM   #6
As long as the romex isn't exposed when everything is complete, you're fine.
Be sure and be careful when you put the dishwasher in place(nothing resting on the romex), because years of use with the vibrations of the machine will wear right through the cable.
Sparky Joe is offline   Reply With Quote
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Dishwasher don't drain all the way MattCoops Appliances 8 04-17-2007 10:07 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
Dishwasher Drain Question kypper Plumbing 2 01-15-2007 11:39 PM
