Dishwasher Circuit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 07:30 PM   #16
Rewards Points: 2,350
Originally Posted by Knucklez View Post
from NEC 2008
when i read this, i think my DW is not over 300V, so i can use the breaker panel as the ON/OFF. no mention of locking device requirement here (but probably elsewhere in NEC). doi understand this correct?
That's 300 VA, aka watts, not volts. Check the name plate, it probably has a heater, and draws more than 300 watts. Look at 422.31(B)
Old 07-09-2009, 07:06 PM   #17
Knucklez's Avatar
Rewards Points: 932
oh, you're right. i was wondering...
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 07-09-2009, 09:42 PM   #18
Rewards Points: 502
Originally Posted by theatretch85 View Post
I have never seen a dishwasher with a disconnect other than the breaker in the main panel. Every dishwasher I have seen has been hardwired in and usually shares a MWBC with the garbage disposal. Of course the garabage disposal I have seen both plugin and hardwired versions and always has a switch above the countertop.
My dishwasher is hard wired and then above it, is a wall switch that can turn it off. It is in a double gang box with the switch for the disposal.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 07-09-2009, 10:39 PM   #19
Rewards Points: 506
Send a message via AIM to theatretch85
There is a double gang box above my dishwasher too, but one switch controls the light over the sink, the other controls the garbage disposal. This box also has 3 circuits running to it, one for the light, and a MWBC to split out for the garbage disposal and the dishwasher (so it wouldn't be difficult to put in a switch for the DW).
Since I'd imagine this dishwasher uses more than 300Va, it probably should be required to have a disconnect, but honestly I am not going to worry about it. I've done plenty of work already updating and changing things to meet code around here and putting in a switch for the DW is hardly one I am worried about.
theatretch85 is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Does a Dishwasher need it's own dedicated circuit? Casey_Oakland Electrical 46 02-22-2009 06:35 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
