Discontinued 220v For Micro - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 11:35 PM   #1
discontinued 220v for micro
I am remodeling my kitchen and have 2 existing 20 amp circuits but no dedicated circuit for the microwave. I do however have a 30amp 220v circuit that was for a cooktop that will no longer be used. It is 10-3 wire but without ground. Not sure how to utilize it without the ground. I would change the breaker to a 20 amp. Can I use this wire?
figgy is offline   Reply With Quote
Old 02-27-2013, 11:48 PM   #2
" Euro " electrician
frenchelectrican's Avatar
I worte the underline part and it is not the best thing you can use the non grounded NM cable to extend the circuit.
I know it can be reused for other purpose but did you take a closer look to make sure it was not being cut off on ground conductor otherwise look at the cable marking it will tell the size and if it came with ground or not.
Merci,
Marc
Old 02-27-2013, 11:57 PM   #3
I striped the casing back hoping to find a ground wire but there wasn't one.
I did not read the cable marking but can see it is at least 10-3 and as I said it is a 30 amp circuit. The cooktop that was attached to it had the ground and neutral from the cooktop both attached to the neutral of the romex.
Old 02-28-2013, 12:19 AM   #4
Then it is one of the older NM cable which I know they used come with either grounded and non grounded verison.
While you are doing the remodeling in the kitchen it will be a good time to bring in new circuit for the microwave unit and ditch that old cooktop circuit.
Merci,
Marc
Old 02-28-2013, 12:48 AM   #5
Merci,
Marc
I was afraid you were going to say that. Very difficult to get a new 20 amp circuit from the panel to the micro, that's why I was hoping to use the 30 amp circuit. Otherwise I will probably just tie into on of the 2 existing 20 amp circuits. The micro is only 1000 watts so I might be alright
Old 02-28-2013, 07:04 AM   #6
Rewards Points: 1,214
" The micro is only only 1000 watts so I might be alright"
You might not be alright, follow the recommendation by the frenchelectrican.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-28-2013, 07:55 AM   #7
Rewards Points: 948
Maybe I am missing something here, but...
It has two hots and a neutral; no ground. In my old house all the 240v was like that; in mine it was a "uninsulated neutral".
Use one hot as a hot, one hot as a neutral, and the neutral as a ground. What is wrong with that?
Toller is offline   Reply With Quote
Old 02-28-2013, 08:28 AM   #8
Rewards Points: 1,418
Not allowed to use the red or white wire as the ground (equipment grounding conductor).
Not allowed to use the red or black wire as a neutral.
Since you are changing things around, that cable loses its grandfathering and you need to run a new cable. Or, provided you are not extending the circuit, you can run a separate green or bare EGC from that location to the panel exactly, approximately or vaguely following the route of the original cable.
Old 02-28-2013, 12:41 PM   #9
Rewards Points: 309
Would someone please cite the code section that forbids re-purposing a colored conductor (say red) for ground service using green tape?
al_smelter is online now   Reply With Quote
Old 02-28-2013, 12:54 PM   #10
Rewards Points: 309
Never mind, I found it. 250.119
Old 02-28-2013, 11:55 PM   #11
Is there a reason why being very difficult to bring in new circuit ?? was the basement is finshed or what this set up ?
Techally wise if done right you should able open very little drywalls and how far is the kitchen to the breaker box ?
Merci,
Marc
110V from 220v pump circuit DBachman Electrical 10 08-28-2011 12:57 AM
220V & 110V outlets rickinnocal Electrical 21 05-13-2011 02:16 PM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
