Disconnect Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 06:10 PM   #1
Nitwit's Avatar
Disconnect Switches
When a DPST disconnect switch is rated for 200 amps, does that mean per pole or both poles combined?
Nitwit is offline   Reply With Quote
Old 08-15-2010, 07:27 PM   #2
Master Electrician
Rewards Points: 3,808
Per pole.
brric is offline   Reply With Quote
Old 08-15-2010, 07:40 PM   #3
Nitwit's Avatar
Originally Posted by brric View Post
Per pole.
Thanks for the reply but now this raises another question.
A Breaker rated for 200 amps means 100 amps per side, correct?
Old 08-15-2010, 07:41 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
As brric says. It is per pole.
A 30A SP toggle switch, a 30A two-pole single phase disconnect, a 30A 3-phase disconnect or a 30A four pole lighting contactor are all 30A rated devices.
This applies to switches, circuit breakers, panels, etc. Anything that has one or more "poles" or "phases".
Old 08-15-2010, 07:42 PM   #5
No. Poles are NOT combined.
See my last reply.
Old 08-15-2010, 07:54 PM   #6
Nitwit's Avatar
What I meant to say is "A breaker PANEL rated for 200 amps wold take (2) 100 amp mains max?
Old 08-15-2010, 07:59 PM   #7
No a 200a panel takes/supplies 200a on each pole
Go over ~200a on either side & the breaker trips
Old 08-15-2010, 08:07 PM   #8
Nitwit's Avatar
Originally Posted by Scuba_Dave View Post
No a 200a panel takes 200a on each pole
My sticker on my square d panel says 150 amps and I have 2-60 amp mains.
This is why I was confused. So everything is rated amps per pole or side.
Thanks again.
Old 08-15-2010, 08:18 PM   #9
Electrical Contractor
kbsparky's Avatar
How old is that panel? It sounds like you have one of those old-style split-bus panels, with (2) 60 Amp mains there ....
Care to post a picture of the guts of that panel, with the cover removed?
-KB
Old 08-15-2010, 08:19 PM   #10
Electrician
Proby's Avatar
Just to clarify, you have a single 2-pole 60A breaker acting as the main for the panel, correct?
That is normal, you simply have a smaller breaker than the panel can handle. The panel could handle up to 150A, if desired.
A 200A breaker will give 200A on each of (2) 120V circuits. Or it will give 200A on one 240V circuit.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-15-2010, 10:05 PM   #11
Nitwit's Avatar
No, I have (2) 2pole 60 amp main breakers.
Old 08-15-2010, 10:11 PM   #12
Electrician
Proby's Avatar
Yes, a split bus.
Old 08-15-2010, 10:21 PM   #13
Nitwit's Avatar
From 1977. Should I upgrade?
Old 08-15-2010, 10:26 PM   #14
Electrician
Proby's Avatar
I don't know.
I don't know much about split bus panels, when I first saw your picture I thought it was a main lug only panel until I traced some of the wires
Square D QO is a good panel and you can buy new breakers if you are having an issue.
I personally don't see any reason to upgrade unless you are looking for a project.
Hopefully someone else with more splitbus experience will chime in.
Old 08-16-2010, 05:26 AM   #15
kbsparky's Avatar
YOU have more than 2 main breakers there. The entire top section consists of 4 to 6 double-pole breakers, which combined together constitute your "service disconnects". You have to turn them all off to shut down all the power in the premises. The ones labeled "Main" only feed into the bottom sections of the panel -- controlling the single pole loads.
I am more concerned with that breaker labeled "Generator" which is in the off position.
Is that connected to a generator for back feeding the panel? Without a proper isolation interlockit or transfer switch, you have a potentially dangerous situation and a major code violation.
I would upgrade, and install either a generator sub-panel, or a proper interlock kit in the new box.
-KB
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
small solar disconnect switches rescrewableE Electrical 1 01-02-2010 07:55 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 07:45 PM
