Disconnect For Mini Split - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2013, 07:36 AM   #16
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by stickboy1375 View Post
You could run #14 AWG if you wanted.
Also, nobody ever does this, but a disconnect is required on the inside as well... just saying.
Ok I,ll bite ... This is a mini split ...never heard of that one ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 06-18-2013, 08:36 AM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
It's a motor, requires a disconnect inside at the indoor unit for service. Just like every other motor.
I install a 3pole toggle switch with an old work box to keep it clean looking
Old 06-18-2013, 08:53 AM   #18
Rewards Points: 516
it is a very low watt fan motor .... and since the disconnect outside would be "lockable" ( normal A/C disconnect ) i do not think it would need one inside ....
Old 06-18-2013, 09:10 AM   #19
E2 Electrician
Most are 240v motors, what's the wattage have to do with it?
It's like saying the breaker on the panel is lockable so why install a disconnect at the AC unit.
Old 06-18-2013, 09:45 AM   #20
Rewards Points: 516
should have said 1/8 hp or less ...430.109 (B) is where i was going .....
so give or take 100 watts ....
Old 06-18-2013, 09:47 AM   #21
Rewards Points: 516
440.14 Location.
Old 07-03-2013, 07:34 PM   #22
Ok here is what I have so far....I ran the 12/2 wire to the disconnect ( non fuseable) 30A Dbl pole breaker in the panel.
Now I have an electrical whip with 2 #8 thhn conductors and 1 #10 conductor. Is this the only wires that go to the outdoor unit.
the directions are kinda poor.
thanks
amoscara
amoscara is offline   Reply With Quote
Old 07-03-2013, 08:05 PM   #23
Licensed electrician
Rewards Points: 1,470
The two #8 are the hots, the other is the ground.
The disconnect terminals will be labeled Line for the incoming power.
Old 07-03-2013, 08:07 PM   #24
Thanks Jim Port....
Old 07-07-2013, 05:30 PM   #25
One more question and Im good to go,it's probably stupid so don't laugh.
I purchased the electrical whip and it has one straight end and one 90 deg end. is there any preference which end goes on the unit and which goes on the disconnect.
thanks
Amoscara
Old 07-07-2013, 06:09 PM   #26
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Not really. Most of the time, you'll want to use the straight out of the bottom of the disconnect and the 90 on the unit.
wirenut1110 is offline   Reply With Quote
Question: Backfeeding Gen thru Pull-Out Disconnect and GFCI (with interlock kit) diyfram Electrical 7 11-02-2012 10:59 AM
Split Buss? how to disconnect power? tom1973 Electrical 4 01-05-2012 01:01 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
