Disconnect On HVAC Equipment - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2009, 02:51 PM   #1
Disconnect on HVAC equipment
Why do some electricians INSIST on hanging a disconnect on the service panels of roof top equip and resi A/Cs?
Not looking to start a bashing war, but it seems to always happen on the most inaccessible units.
Is there a reason for this that I am just not getting?
Thanks.
hvaclover is offline   Reply With Quote
Old 02-26-2009, 02:54 PM   #2
Electrician
Thanks.
No idea, other than stupidity. Its a code violation to boot, Art. 440.14
chris75 is offline   Reply With Quote
Old 02-26-2009, 03:08 PM   #3
Must be getting lax at the bldg department. I permitted a new roof top unit and the sub mounted it to the control cover panel. Elec inspector is a part timer.
I complained to him and he blew it off. No enforcement. Found out he didn't even go on the roof.
Old 02-26-2009, 03:12 PM   #4
Electrician
I cant believe an electrician would slap a disconnect on a cover he may need access to. A true Git-R-Done if you ask me.
Old 02-26-2009, 03:20 PM   #5
seeing is believing ....this was a permitted job when it was new. The HO put the condenser fan motor in
Old 02-26-2009, 04:27 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
There you go. Best of Craigslist I bet too.
Old 02-26-2009, 04:56 PM   #7
Just to be clear, that is not one of my jobs.
Old 02-26-2009, 05:01 PM   #8
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
That looks like one way to reverse the rotation on a motor
wirenut1110 is offline   Reply With Quote
Old 02-26-2009, 06:46 PM   #9
I've aint never done it. I are smart.
Why don't the MFG's simply build one in?
A lot of times, especially with condersing units, there isn't a decent place to hang one.
The Trane RTU's I installed on my house had an absolutely terrible design to get the power to the control area.
220/221 is offline   Reply With Quote
Old 02-26-2009, 06:49 PM   #10
The HO probably saw the raintite disconnect upside down and followed with the fan motor!!!
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Old 02-26-2009, 06:53 PM   #11
Res Ipsa Loquitur
That's Creative!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-26-2009, 08:23 PM   #12
So where'd you hang it?
Old 02-26-2009, 09:53 PM   #13
and why couldn't we mount the disc. on the wall.... :-?
patriot1 is offline   Reply With Quote
Old 02-26-2009, 10:54 PM   #14
That's the topic of this thread...but that AIN'T one of my jobs.
Old 02-27-2009, 05:59 AM   #15
The only time EVER to mount a disc on a unit is a rooftop installation.
There are KO's on the fixed panels where you can mount it. Thing is the manufacturers are partly to blame because the KO layout is usually terrible.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Lug Only Panel jamiedolan Electrical 26 01-19-2009 02:21 PM
Buying HVAC Equipment EarthCreepin HVAC 3 08-01-2008 09:00 PM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
