Disconnect Distance From Hottub - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2013, 08:42 PM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Disconnect distance from hottub
Hopefully someone can clarify what I cant find in the NEC canada code book.
When mounting my outdoor gfci disconnect switch from my hottub I have read comments online that it needs to be 10' away from the water. I have also read posts where its been said it can be closer since its gfci protected in the disconnect..
Hopefully someone can clarify, thank you.Cheers
ryanh is offline   Reply With Quote
Old 05-24-2013, 09:04 PM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
680.41 Emergency Switch for Spas and Hot Tubs.
A clearly labeled emergency shutoff or control switch for the purpose of stopping the motor(s) that provide power to the recirculation system and jet system shall be installed at a point readily accessible to the users and not less than 1.5 m (5 ft) away, adjacent to, and within sight of the spa or hot tub. This requirement shall not apply to single-family dwellings.
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-24-2013, 09:29 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Philly, did you read the last sentence? That section does not apply, but the 5' from the tub to the disconnect still applies, just under another code section.
To the OP, in the US, the disconnect must be 5' away from the tub.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Philly Master (05-25-2013), Speedy Petey (05-25-2013)
Old 05-24-2013, 11:56 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Here in France the disconnect for hot tub is 2 meter max distance but for commercal useage it will be 1.5 meter or on the hottub itself depending on the local codes we get into.
But I know in USA side it will be 1.5 meter however check with your local codes they may change it so be aware for any last minuite changes.
Merci,
Marc
Old 05-25-2013, 06:32 AM   #5
Rewards Points: 516
Yes min 5' .... Max 50'
Must be line of sight... Lol yea same thing sorry was going fast
Old 05-25-2013, 06:45 AM   #6
Rewards Points: 516
Ok I yield ...lol. 680.12 then...
Old 05-25-2013, 08:59 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Not to start anything , it's the same thing, so why does code go to the trouble of addressing "this does not apply to SFR's"
I'm sure there is an explanation... just my criticism of code being so complex and often confusing, clearly time consuming, that I sometimes think it's designed intentionally to be it's own industry.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-25-2013, 09:09 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Because the emergency switch that the code refers to is not nearly the same thing as a service disconnect.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
brric (05-25-2013), stickboy1375 (05-25-2013)
Old 05-25-2013, 09:11 AM   #9
E2 Electrician
Just my guess, but in commercial atmospheres, I nice big red mushroom button is easy to spot and engage when people get into a panic situation.
The Following User Says Thank You to stickboy1375 For This Useful Post:
MTN REMODEL LLC (05-25-2013)
Old 05-27-2013, 05:00 PM   #10
ryanh's Avatar
Rewards Points: 154
Thanks guys.
Cheers.
Question: Backfeeding Gen thru Pull-Out Disconnect and GFCI (with interlock kit) diyfram Electrical 7 11-02-2012 10:59 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
Distance for Disconnect? sandyman720 Electrical 12 09-18-2007 09:20 PM
