Disconnect For AC GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 11:16 AM   #1
Rewards Points: 152
Disconnect for AC GFCI?
Does a circuit that is dedicated for a AC compressor have to be on a GFCI circuit?
sandyman720 is offline   Reply With Quote
Old 11-26-2007, 11:41 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
NO..... not for the compressor circuit..... but it is required to have a maintenance disconnect outside near the unit condenser. And also a 120 volt GFCI service receptacle close by.
This is a good option if you need both...note that a seperate circuit must be run to the 120 volt gfci receptacle.
This image below shows the required receptacle and you can also see the required A/C disconnect mounted to the side of the house.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
GFCI protection for Shop/Garage Sub-Panel porterpearl Electrical 3 01-06-2006 04:33 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
