Old 05-22-2011, 09:21 AM   #1
disabling a smoke alarm
can i disable a smoke alarm and install my own smoke ditector
mr well is offline   Reply With Quote
Old 05-22-2011, 09:47 AM   #2
Why would you want to disable a smoke alarm?
josall is offline   Reply With Quote
Old 05-23-2011, 12:34 AM   #3
A smoke alarm is a stand alone unit, may be battery powered, 110V or 110V w/battery back up. By stand alone unit I mean it is not wired to a fire or burg panel. It may be wired other smoke alarms
A smoke detector is wired to a fire or burg panel.
Do you have a smoke alarm or smoke detector?
If it is a smoke alarm, you can install a smoke detector in its place. You are aware the smoke detector needs to be compatable with the fire or burg panel?
there are wireless smoke detectors also, but the panel must also be wireless.
fireguy is offline   Reply With Quote
Recessed Smoke Detector / Fire Alarm / Other Names for Things that Beep Around Fire Fox Electrical 12 07-26-2010 03:42 PM
smoke alarm was sealed off in finished basement Stl_home General Discussion 4 06-22-2010 08:47 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 09:09 AM
Hard wired smoke alarm in NYS ADKstorm Electrical 12 04-30-2009 10:58 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
