Direct Wire A Vanity Miror - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 11:46 AM   #1
pjs
Direct wire a vanity miror
We purchase a Conair wall mounted mirror which has a two-prong plug. My previous mirror was direct wired.
Is it safe to cut the plug off the new mirror and direct wire it in the electrical box that already exists?
pjs is offline   Reply With Quote
Old 02-28-2009, 12:11 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
I am not an electrician but I don't believe what you are proposing is recommended. Why not put a receptacle in the electrical box that already exists and plug the mirror to it?
Bocolo is offline   Reply With Quote
Old 02-28-2009, 12:16 PM   #3
pjs
Thanks for the feedback. This is actually a make-up mirror which pulls very little power. I have an outlet directly but then the cord would be exposed. If I cut off the plug and direct wire it, them I am concerned the wire might get oo hot and cause a fire. Might be an over reaction on my part.
Old 02-28-2009, 12:24 PM   #4
Rewards Points: 2,350
Don't direct wire it, no, no. Maybe you can install a clock receptacle behind it to plug it in? GFCI protected of course.
Old 02-28-2009, 12:56 PM   #5
Rewards Points: 82
Agreed. This is what I would do. Even if the receptacle did not exist. I would install the clock type (recessed) receptacle. Then you will not see the cord.
Use the a receptacle that matches the plug on the mirror. Never modify a UL listed device.
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 12:46 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
direct wire a range j1mw3b Electrical 7 02-16-2008 03:40 PM
Converting plug-in undercabinet light to direct wire ccole10 Electrical 4 07-21-2005 11:58 AM
