Direct Short - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 01:38 PM   #1
Direct short
I replaced a switch that I thought was bad. When I turned power back on and fliked the new switch it sparked but did not trip the breaker. I then checked the old switch because I was at wits end. It check out OK as did the new switch after the direct short issue. I did the check with a continuity meter. Any help appreciated.
hammerdawg is offline   Reply With Quote
Old 05-31-2011, 01:40 PM   #2
joed's Avatar
Rewards Points: 13,728
The switch was installed in the box with one of the screws touching the side.
or
The ground wire was touching the one of the screws.
or
There is a bare spot on one of the wires that was touching the box.
or
Old 05-31-2011, 02:13 PM   #3
Rewards Points: 512
pictures? how many wires in the switch box, and what condition are they in; older wiring or newer? Did you do more than simply disconnecting two switch leads on the old, and reconnecting on the new switch?
Old 06-01-2011, 12:22 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
or
the line in and neutral are hooked to the switch
or
there is a short in the wiring leaving the switch box
or
the load the switch is controlling has a short
or
the wiring at the load has a short
or
Kyle
Furnace short cycling repman55 HVAC 12 01-21-2011 04:41 AM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 03:27 AM
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 12:54 PM
Direct Vent or Free Gas Fireplace rocketdoctor HVAC 1 04-12-2009 06:47 AM
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 11:46 AM
