Dining Room Receptacle Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 09:25 PM   #1
Dining Room receptacle wiring
I have to move a plug under a window due to me putting in a sliding patio door in my dining room. I decided that since I had some drywall off and had to move a receptacle, Id bring things up to code. I will have 6 dining room receptacles that I want to add to my kitchen SABC's. There will be no kitchen or dining room lighting on either SABC. What is the best way to wire in the dining room receptacles? Does the dining room have to be Arc Fault protected? If I dont wire the dining room in to the Kitchen SABC's Can I run ONE 20A circuit for the dining room?
Thanks Scott
SW315 is offline   Reply With Quote
Old 02-08-2012, 09:55 PM   #2
Rewards Points: 776
Thanks Scott
What is a SABC?
curiousB is offline   Reply With Quote
Old 02-08-2012, 09:57 PM   #3
Originally Posted by curiousB View Post
What is a SABC?
Small Appliance Branch Circuit
Old 02-09-2012, 01:36 AM   #4
Julius793's Avatar
Thanks Scott
Ideally a dining room should have it's own 20a circuit.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-09-2012, 09:06 AM   #5
Licensed electrician
Rewards Points: 1,266
There is a good chance the existing receptacles are already on the kitchen receptacle circuits.
Old 02-09-2012, 05:43 PM   #6
House was bult in 1964. The receptacles were on the lighting circuit, they have since been removed from that circuit. Now Im trying to figure out if it's better to tie in with kitchen or run separate circuit.
Old 02-09-2012, 06:02 PM   #7
Electrical Contractor
jbfan's Avatar
If you have the space I would run a new circuit.
Are you sure the exsisting sabc are up to code?
jbfan is online now   Reply With Quote
Old 02-09-2012, 06:08 PM   #8
As far as i know they are.
Circuit 1 has two countertop receptacles gfi protected
Circuit 2 has fridge, 2 countertop receptacles and gas stove receptacle.
That is code correct?
Old 02-09-2012, 06:11 PM   #9
jbfan's Avatar
That is correct.
Old 02-09-2012, 06:15 PM   #10
Looks like I will run a new circuit i have a few spaces left in the panel.
Thanks again for your time!
Old 02-09-2012, 06:28 PM   #11
Double post
Need help with a remodel of dining room and bathroom bluelinebrotha Interior Decorating 4 01-29-2012 03:40 PM
urgent help needed: wiring at a receptacle mudworm Electrical 7 10-17-2011 12:03 PM
Wiring a new living room addition ryan5068 Electrical 3 06-25-2011 06:09 PM
Charred / melted wall receptacle, AL wiring in house creamaster Electrical 17 12-04-2009 05:47 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 05:08 PM
