So, here is a brief history of the problem:
February: lights flicker and pop while it is raining lightly. No problem for two weeks (had every intention of getting electrician out soon). Two weeks later light rain again lights flicker, pop and PoCo meter catches fire and burns up. Meter is pulled, emergency electrician comes out, can't find anything that would have caused the wires to burn so they assume there was a loose connection - tightened connection in panel and check everything out and meter is replaced.
March: lights still flicker randomly. Mainly when my AC kicks on. AC repair man comes out 3 times - AC is in perfect condition with new hard start kit. Lights still flicker. Call different electrician - he goes through my house and can't find a problem so he suggests its a loose neutral on PoCo side. Now starting to notice lights flicker everytime neighbors AC kicks on.
April-present: POCO has come out close to 15 times changing connections, switching my house to different transformer, replacing transformer, tightening connections. Problem isn't solved - after they supposedly replaced transformer our problems got worse. Brownouts, flickering lights, electronics failing (maybe coincidence cable box stopped working, cell phone, vacuum cleaner, light bulbs burn out constantly). One thing that did change was when our house was switched to a different transformer (not a new one just a different one) our lights would flicker at random and a little less frequently)
Any suggestions?
Any suggestions?
