Dimming Lights With Spiking Voltages In House - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 07:23 PM   #1
Dimming Lights with Spiking Voltages in House
Need some advice folks. For the past 6 months, the lights flicker and dim in our house...appliances slow down and struggle, window AC units almost stall, and sometimes it sticks that way for 10 minutes at a time. Put a meter in my 110V outlets and found out that when the browning/dimming is happening, it reals 145V! Then when everything gets bright and normal again, it reads 125V. Just the opposite of what I would expect. Its an old house with old wiring and an old panel box still on the outside of the house. Last electrical update I know of was done 35+ years ago. Could it be the box? I dont see how the voltage can go UP unless there is some bleeding from the 220 side? I dont know much about electricity, so I need some advice. Thanks.
P.S.
I did have an electrician check it out some months ago, and he updated a bar or contact or something in the box, and we thought that fixed it, but it didnt.
Anquan is offline   Reply With Quote
Old 07-19-2009, 07:42 PM   #2
dSilanskas's Avatar
You need to call the local utility company. Sounds like you have an issue with you feeders.
dSilanskas is offline   Reply With Quote
Old 07-19-2009, 08:40 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
Sounds like a loose netural, either in the panel, meter, or POCO connections.
Call POCO first, then call another electrician.
Old 07-19-2009, 08:41 PM   #4
Your bad neutral connection has 145-125=20vac across it. If you pull 10A on one side of your neutral and 1A on the other, your bad connection will dissipate (10-1)20 = 180w and will get warm or hot.
Your stuff that is on the 145v side has had its life shortened, especially incand. bulbs.
With 250vac into your house the xformer must be right out front. Mine reads 246vac with the xformer right out front.
Old 07-19-2009, 08:56 PM   #5
6 months?
1. Call the power company today, it's free.
2. If it is not on their end, call an electrician to find the obvious neutral problem before you ruin you TV's and appliances.
6 months???
220/221 is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
lights dimming when using the vacuum farmerde Electrical 21 12-08-2008 08:09 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
randomly dimming lights on one circuit Swansen Electrical 6 04-23-2008 07:58 AM
