Dimmer Switches To Lamps To Plug In Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 10:34 AM   #1
Dimmer switches to lamps to plug in outlets
Hey, I'm putting together a music/light show and I've got some questions about using dimmer switches. All the online tutorials on how to install dimmer switches are for people wanting to change the lighting in their houses. What I need is to have say, 5-7 lightbulbs (probably in lamps or some really simple fixture, and each bulb will be either 40 or 60 watt incandescent) controlled by dimmers that I can just plug into a powerstrip for portability. Each light needs to be able to be dimmed independently of each other.
keithansel is offline   Reply With Quote
Old 03-22-2011, 10:53 AM   #2
Rewards Points: 1,512
See if you can find metal boxes (start with the 4 inch square boxes) that will fit the dimmer with its special cover plate and a standard duplex receptacle. Or one box that holds two dimmers and another box that holds two duplex receptacles; they make a cover for the latter. Connect multiple boxes together using nipples and fasten them all to a piece of 1x6 lumber or plywood. Add one cord and plug for power to this portable conglomeration. If you insist, you can break off the tab between the gold screws of a duplex receptacle so each dimmer serves just one half and four dimmers in two boxes feed two duplex receptacle units in a third box.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
GFCI Outlets in Series allbymyself Electrical 6 01-24-2011 11:52 PM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
