Dimmer Switches Humming - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 11:56 PM   #1
I just installed 3 Lutron Toggler dimmer switches. The 1st one is not humming, but the 2nd 2 are. Can someone tell me why the actual switches (not the bulbs) are humming? They are all single pole 600w switches.
jcasey is offline   Reply With Quote
Old 01-29-2011, 06:33 AM   #2
What is on the dimmers?? Standard dimmers don't like loads like fans or transformers.
Old 01-29-2011, 06:56 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
or CFL bulbs
Coastal South Carolina
Old 01-29-2011, 09:36 AM   #4
Rewards Points: 93
I was just going to ask this same question. I just installed a Lutron dimmer in a 3-way circuit and heard a humming sound, louder when dim but goes away when turned all the way up. The dimmer is made for CFL bulbs but can also work with incandescents. I'm switching over to CFLs as the incandescents burn out, so right now I have a mix of incandescents(8) and CFLS(4). jcasey, is this similar to your situation?
scottyv81 is offline   Reply With Quote
Old 01-29-2011, 09:40 AM   #5
A "Handy Husband"
rjniles's Avatar
Are you using CFL's that are rated for dimming?
Old 01-29-2011, 01:50 PM   #6
Rewards Points: 93
Don't want to hijack the OP's thread, but yes the CFLs are dimmable.
Old 02-01-2011, 03:52 AM   #7
Sorry I disappeared guys! On the 1 that's not humming there are 4 recessed 60 watt incandescent bulbs (Sylvannia and Philips). On the one that hums a little I had 3 - 57 watt GE Edison Halogens on 1 fixture. I replaced them with GE Reveal 60 watt A19 bulbs and the hum diminished a little. The one that is the worst is has 2 - 65 watt Teiber incandescent bulbs in 2 fixtures. These have been in the fixtures since the house was built so they came out of a contractor pack. I'm using no CFLs. And Scotty just like yours the lower the light is the louder the hum.
I spoke w/ a cs rep at Lutron and they claim that a cheap bulb or one with a long filament will cause the filament to vibrate creating the hum in a choke in the switch. My concern is the one with a medium hum got warm after it was left on for a little while. Any idea why it gets warm?
Old 02-28-2011, 08:49 AM   #8
My recommendation would be to replace them with better bulbs. Usually Philips work well. As far as the dimmer getting warm that is typical because it is a triad base dimmer. Your are essentially turning the light on and of 60 times a second. The triac uses the metal yoke as a heat sink. If one is significantly hotter than the others then you may have a problem.
Ehsoccer15 is offline   Reply With Quote
Old 02-28-2011, 11:17 AM   #9
Rewards Points: 131
What would you suggest for fans?
HitLines is offline   Reply With Quote
Old 02-28-2011, 12:13 PM   #10
Just call me Andrew
Rewards Points: 1,020
There are lots of switches specifically designed for fans...
Personally, I like the Lutron Maestro series:
http://www.lutron.com/Products/Stand...es/Models.aspx
Andrew
secutanudu is offline   Reply With Quote
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Dimmer humming, screws warm abefroman Electrical 6 11-12-2009 08:55 PM
Higher wattage dimmer switches? jamiedolan Electrical 25 11-10-2008 08:41 AM
dimmer switches alansax Electrical 1 06-19-2008 11:05 AM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
