Old 06-19-2008, 05:59 AM   #1
dimsparks
Question
dimmer switches
can anybody help me, i have undercupboard lighting and downlighters in the ceiling all from 1 double switch. the downlighters are dimmable but the undercupboard striplights are not. i am trying to find a double switch that has a dimmer and an ordinary on/off on the same switch. the origanal switch has two dimmer type swiches with the undercupboard one made to just switch on/off, but this has started to fizz..thanks
alansax is offline   Reply With Quote
Old 06-19-2008, 12:05 PM   #2
J. V.'s Avatar
dimmer switches
Do you have two separate switches, the dimmer and a simple snap switch on two yokes? (two gang box). If you only have one switch for both (single gang box) on one yoke, I would try googling switches + electrical. I have never seen a dimmer and a snap switch on the same yoke (together as one device).
Someone here will be able to assist you. Just keep an eye on this post.
Tags
dimmer, fizz, switches
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 08:28 PM
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 01:33 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
