Dimmer Switcher Help - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 11:39 PM   #1
So I bought an electronic dimmer switcher (The kind that fades the lights when turning them off and on). Anyway the old switcher has two black wires going to it. I'm not sure how to hook it up to the dimmer because it is asking for black and red. Any thoughts?
Also, should I connect the ground(green screw) as well even though the old switch did not have one?
soasquad is offline   Reply With Quote
Old 09-21-2010, 11:53 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there should be a diagram with the dimmer. I can't remember for sure but I believe the black is typically the line side (hot wire connects there) and the red is the load side (goes to the light).
so, you figure out which of the two wires is the hot, line, feed, whatever you want to call it and connect that to the wire the directions tell you to. Then, you connect the remaining black wire that goes to the light to the remaining wire on the dimmer.
yes, if there is a ground screw, you need to attach the egc (ground wire) in the box to it.
Old 09-22-2010, 08:58 AM   #3
So I should attach the (-) lead of my voltmeter to the white wires tucked away in the back of the box and then check to see which black wire is hot with the (+) lead?
Old 09-22-2010, 09:05 AM   #4
Rewards Points: 779
since you are attempting to read volts ac (selected on multimeter), the leads are not polarized as in dc voltage readings. your meter will read correctly with the leads in either position.
TimPa is online now   Reply With Quote
Old 09-22-2010, 10:06 AM   #5
nap
You talking to me?
nap's Avatar
I would check to the ground wire (bare or green). Not knowing what all you have in the box, there are times where the white wire (although it should be remarked as a black) is used for a hot wire or switch leg.
4 way dimmer jamiedolan Electrical 7 08-24-2010 01:45 AM
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 12:19 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 06:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
