Dimmer Switch Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 07:36 PM   #16
joed's Avatar
Rewards Points: 11,598
The old switch did not have neutral wire. It had a white wire but not a neutral. What you have is a switch loop. The white is being used as a hot wire.
That dimmer is a three way dimmer.
The switch has two wires + maybe a ground.
The dimmer should have two wires + ground.
Take two wires off old switch and connect to new dimmer.
That dimmer you have might work if you use the common screw(black one) and one of the travellers. The dimmer function could also be bad in that switch if it doesn't dim.
Old 01-12-2011, 07:48 PM   #17
Licensed electrician
Rewards Points: 1,038
Originally Posted by Stcrosby View Post
jim thanks for your time.
I'm trying to understand what you are suggesting. Is this correct, I need to remove and seperate the wire nut(above the light fixture) and splice the white wire coming from the junction box to the white exiting the light fixture going to the switch? Then splice the black wire returning form the switch to the black wire entering the fixture from the junction box??
Also, the switch claims it can be used as a single pole or a 3way.
I think you have it.
Old 01-13-2011, 05:49 AM   #18
Much appreciated guys.
Stcrosby is offline   Reply With Quote
Replacing dimmer switch with regular switch? LOUSY CARPENTER Electrical 2 11-05-2010 08:21 PM
The Wife said, "The lights are flickering." Dimmer on aluminum wiring Law911 Electrical 4 03-26-2010 12:19 PM
wiring dimmer switch raineydr Electrical 5 03-17-2010 12:17 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
