Dimmer Switch Wired To Receptacles? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 10:07 PM   #16
Rewards Points: 1,444
And if you die?
mikegp is online now   Reply With Quote
Old 02-01-2013, 11:24 PM   #17
Rewards Points: 578
if i die my fiance gets it. if he dies then it would belong to my parents and most likely sit empty until it rots
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 02-01-2013, 11:37 PM   #18
Journeyman Wireman
Rewards Points: 150
Originally Posted by TrailerParadise View Post
Little chance of that... These two (if it was to be done this way) would be behind the bedside tables and like i said, only lamps would be plugged in here. Plus its all wood floors, so really, no chance of that.
When I ran a residential service truck I ran into a problem where the customer was complaining that her vacuum wasn't working right in a particular receptacle. The receptacle was showing 82 volts hot to neutral. I spent 3 hours trying to track down the problem. I never did find one. What I did find was a dimmer switch way across the room behind a wall hanging that the customer had forgotten was there.
Lesson of this story. Not only is it a code violation to use a dimmer on a receptacle, it can also be a very expensive learning experience.
Jupe Blue is offline   Reply With Quote
Old 02-02-2013, 09:37 AM   #19
PoleCat's Avatar
Rewards Points: 1,646
I mounted the dimmer switches on my head board and hard wired them to the lamps. We like it and the outlet stays code.
PoleCat is offline   Reply With Quote
Old 02-02-2013, 09:29 PM   #20
Rewards Points: 578
i took the dimmers back and will put in a normal switch. no biggie.
Old 02-02-2013, 11:21 PM   #21
Electrical Enthusiast
Rewards Points: 504
Guess everyone can breathe a sigh of relief now...
Kyle_in_rure is offline   Reply With Quote
replacing an existing 1-way decora light switch with a dimmer switch maljeff Electrical 3 01-11-2012 12:49 PM
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 10:51 PM
Replacing dimmer switch Mike2181 Electrical 4 10-26-2009 02:12 AM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 01:25 PM
