Dimmer Switch Will Not Work - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 09:46 PM   #16
Licensed Pro
By any chance are you hooking the dimmer up with the power still on? Doing so may fry the dimmer.
Old 07-26-2011, 07:47 PM   #17
Smile
I was born on a Monday but not yesterday!!
Penn State is offline   Reply With Quote
Old 07-26-2011, 09:33 PM   #18
dmxtothemax's Avatar
Rewards Points: 5,096
Do these dimmers need a neutral ?
If you have a two wire switch loop,
Then there may not be a neutral.
dmxtothemax is offline   Reply With Quote
Old 07-26-2011, 11:43 PM   #19
" Euro " electrician
frenchelectrican's Avatar
I will suggest that why not post the photo that will really clear up the matter on this one.
Merci,
Marc
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 01:37 PM
Help with simple dimmer switch install nikeman Electrical 10 11-08-2010 11:10 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 04:26 PM
Ceiling Fan + Dimmer Switch = BUSTED brianm Electrical 3 01-31-2010 10:28 PM
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 02:31 PM
