Dimmer Switch Will Not Work - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 08:26 PM   #1
Dimmer Switch will not work
Trying to hook up a dimmer switch for my dining room light but can only get the lights with the dimmer to go off and on. It will not dim and also tried a new dimmer switch with same results. Tried to hook up the wires with all options I know but same result. NEED HELP as this problem is driving me crazy.
Penn State is offline   Reply With Quote
Old 07-24-2011, 08:40 PM   #2
A Little Of Everything
Rewards Points: 1,356
Is it a 3-way switch set-up?
DrHicks is offline   Reply With Quote
Old 07-24-2011, 08:53 PM   #3
Mad Scientist
What kind of lights?
McSteve is offline   Reply With Quote
Old 07-24-2011, 09:35 PM   #4
" Euro " electrician
frenchelectrican's Avatar
And what model number dimmer you have ?? as other two members stated they are right on the spot and also how many conductors in the switch box as well.
If that is three way there may a issue with connections.
Oh by the way if you use the CFL bulbs most cheap CFL are NOT dimmable at all only few are dimmable { only if marked or stated } Ditto with LED's
Merci.
Marc
Old 07-25-2011, 12:40 PM   #5
NO it is not
Old 07-25-2011, 12:43 PM   #6
Question
Merci.
Marc
It is a 12 or 14 conductor. And not using CFL but in condesents
Old 07-25-2011, 01:45 PM   #7
I=E/R
a7ecorsair's Avatar
There shouldn't be any "options" as the dimmer should have only two screws and you should have only two wires. How many watts of light bulbs does the fixture have?
a7ecorsair is offline   Reply With Quote
Old 07-25-2011, 02:52 PM   #8
Wires into the switch black , green & white coming from my C/B box (black is only wire that is hot) 3 wires coming from my light fixture black, white & green. 3 other wires black, green & white coming from a wall recep.
Put a jumper wire (small black) onto the hot wire nut them with with 1 hot going to 1 of the two black wires on the dimmer switch and the other hot black over to the wall recep. black. Ran the black coming from the light fixture the other black coming off the dimmer switch. Tied all the remaining whites together and then tied all the grounds (greens) together. Using 40 watt incondesent bulbs in the fixture. When I turn the dimmer on the fixtures it only goes on and off and will not dim? Replaced the dimmer with another with the same result. NEED HELP SOLVING THIS with someone that knows electrical trouble shooting. I have changed many dimmers but never ran into this problem?? HELP!!!!!
Old 07-25-2011, 03:26 PM   #9
is this the type of dimmer that the knob rotates to dim the lights or does it have a slider on it?
Old 07-25-2011, 03:41 PM   #10
I tried both??
Old 07-25-2011, 03:51 PM   #11
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Did it work at one point? I've seen dimmers act that way after they've been shorted out. Did you maybe short it by accident the first attempt? Basically that would be hot and neutral going straight to the dimmer. Some poof noise would probably have been heard along with a tripping breaker. Or it could be defective out of the box.
Old 07-25-2011, 03:52 PM   #12
question: why did you have to connect so many wires when you changed from the switch to the dimmer? it should have been unhook 2 wires from the switch and hook 2 wires to the dimmer. what red squirrel said too
Old 07-25-2011, 06:19 PM   #13
I will not dim but works fine (on/off) with single pole switch.
Old 07-25-2011, 06:21 PM   #14
You need two hots!! One going to the switch and jumping over to the wall out so it can be hot all the time.
Old 07-25-2011, 06:23 PM   #15
I could see one defective dimmer but not two different brands?
2 way dimmer & 3 way switch paulegan25 Electrical 14 11-22-2010 01:37 PM
Help with simple dimmer switch install nikeman Electrical 10 11-08-2010 11:10 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 04:26 PM
Ceiling Fan + Dimmer Switch = BUSTED brianm Electrical 3 01-31-2010 10:28 PM
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 02:31 PM
