Dimmer Switch Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 06:32 PM   #1
sweaty
Rewards Points: 276
Dimmer Switch questions
My dining room has a 3-way switch with a dimmer. The dimmer gets warm and the heat can be felt through the plate. Opening it up, it has no brand name, two backstabbed black wires (no screws), and the ground was not connected. Trying to remove it without cutting the wires, I turned and twisted the wires, but they would not come out.
Should it get hot? Is it a lousy switch? Must I cut the wires to replace it?
sweaty is offline   Reply With Quote
Old 11-19-2011, 07:12 PM   #2
Code05's Avatar
Rewards Points: 1,104
Dimmers get very,very warm, but they should not be hot.
Are sure it is backstabbed? The romex goes straight to the device or are there pigtails in the box?
You should have 3 wires plus ground for a 3-way.
Code05 is offline   Reply With Quote
Old 11-19-2011, 07:30 PM   #3
Licensed electrician
Rewards Points: 1,506
I suspect the dimmer came with wire leads out of the body of the dimmer.
Old 11-19-2011, 07:53 PM   #4
Code05's Avatar
I agree, I have not seen a direct wire resi dimmer. I got I pic for the OP.
Old 11-19-2011, 08:02 PM   #5
Code05's Avatar
Just noticed, my pic has two violations of 200.7(C)(2).
(2) Where a cable assembly contains an insulated conductor
for single-pole, 3-way or 4-way switch loops and
the conductor with white or gray insulation or a marking
of three continuous white stripes is used for the
supply to the switch
but not as a return conductor from
the switch to the switched outlet. In these applications,
the conductor with white or gray insulation or with
three continuous white stripes shall be permanently reidentified
to indicate its use
by painting or other effective
means at its terminations and at each location
where the conductor is visible and accessible.
Old 11-19-2011, 08:06 PM   #6
Missouri Bound's Avatar
Dimmers get hot because they become part of the load. If you have 300 watts of incandescant lighting on a dimmer, and you dim it to about 1 /3.... the other 2/3 becomes becomes heat at the dimmer. And dimming lights does not save energy, it merely converts light to heat.
Old 11-19-2011, 08:28 PM   #7
Code05's Avatar
The older dimmers did not save energy, but I believe many of the newer ones do.
Old 11-19-2011, 11:49 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,202
WRONG !!!
It does not convert the other 2/3s to heat.
It simply switchs the light off during the other 2/3s of the cycle.
Some heat is generated, but NOT 2/3s.
dmxtothemax is online now   Reply With Quote
Old 11-20-2011, 07:26 AM   #9
sweaty
Rewards Points: 276
After another look, this switch has two attached wires that go to wire nuts.
I have two concerns:
I don't want to use electricity to just generate heat.
I want to use the available ground wire.
Old 11-20-2011, 07:41 AM   #10
Newer dimmers are supposed to save energy.
Connect the ground wire to the new dimmer.
Enjoy.
Newer dimmers are coming without the wire leads and are using screw terminals.
Old 11-20-2011, 08:22 AM   #11
Civil Engineer
Rewards Points: 4,702
The posts are generally spot on. Old dimmers used a variable resistor to reduce the circuit voltage, and effectively wasted the unused energy by converting it to heat. Most new dimmers use a triac, which effectively shuts the voltage off for periods of the cycle, thereby reducing the effective power to the bulb without wasting much energy at all. Low quality triac dimmers have the odd effect of making the lightbulb buzz, while higher quality dimmers include various additional circuitry to reduce the buzzing effect.
Not all lightbulb types are compatible with dimmers, for example some CFLs are not suitable for dimming, I don't know about LED's. Make sure the bulbs you use are rated for use with the dimmer you buy.
Dimmer switch burned out my fan lights?? Dannery Electrical 1 09-14-2011 08:58 PM
3 Way Dimmer Light Switch Problem psubaron Electrical 4 07-13-2011 08:08 PM
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 01:28 PM
Dimmer switch wiring question joez148 Electrical 2 07-15-2010 10:49 AM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-16-2007 11:44 PM
