I wired an addition on a house, Added a 20 amp breaker, 12/2wg romex, so its a fresh circuit. Brought power from panel to a double gang box, inside box is one single pole switch and one dimmer switch. Dimmer switch controls inside lights on addition and single pole controls 2 outdoor lights.
Here's my problem, inside light works perfect but outside lights flicker, the inside lights are flourescent lights special made for the dimmer switch, however outside lights are regular screw in type flourescent bulbs. Is it possible that dimmer switch is causing feedback to outside bulbs b/c of them being on the same source of power?
