Dimmer Switch Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 06:30 PM   #1
Dimmer switch question?
I bought some dimmer switches and I am connecting two switches on one circuit controlling two seperate lights. The dimmer I have have two red wires one says only to b used if using for 3 way. There are no white
Wires. Do I have to pigtail all my black connections together? The diagram I am using shows a regular switch
With the black wire on either side of the switch.
jamestown55 is offline   Reply With Quote
Old 01-29-2014, 06:43 PM   #2
Rewards Points: 6
It's not clear to me what you are doing.
Are you replacing two existing switches in the same box with one dimmer?
What color and how many wires are in the box?
What color and how many wires are on the dimmer?
Dan
djlandkpl is online now   Reply With Quote
Old 01-29-2014, 06:48 PM   #3
I am installing them right from the panel I am finishing my basement.
So two switches off one power wire from the panel. Each switch controlling
There own ligjt. There are two red wires, one black
And one green wire on my new dimmer.
Old 01-29-2014, 06:55 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
What brand and model #.
Connect the power from the panel to the black wire and the wire to the light to one red wire, cap off the other red wire.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
djlandkpl (01-29-2014), jamestown55 (01-29-2014)
Old 01-29-2014, 06:58 PM   #5
Leviton decora no 6633
Old 01-29-2014, 07:43 PM   #6
joed's Avatar
Rewards Points: 11,560
Cap the wire with the label. connect the black from each switch to the power black(all three in one wire nut). The remaining red wire of each dimmer goes to feed the lights.
The Following User Says Thank You to joed For This Useful Post:
Old 01-29-2014, 07:53 PM   #7
Great, thanks again.
Old 01-29-2014, 09:06 PM   #8
Did I wire this correctly? I have attached the three black wires together, green ground wires, two white wires from the power source to the red wire on the dimmer switch and then the other red wire to the remaining white wire going to my light.
Old 01-29-2014, 09:25 PM   #9
Rewards Points: 6
It's not correct. The whites get tied together and no wires from the dimmers.
The black from the power source gets pigtailed with the black from each timer.
The red on the timer goes to the black for the light you want it to control.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 01-29-2014, 10:53 PM   #10
Dimmers may need a 40W minimum load.
Dimmer switch question thearchitect Electrical 10 03-05-2013 10:57 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 10:51 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
