Dimmer Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 07:07 PM   #1
Rewards Points: 12
Dimmer switch question
Hello all!
I've installed a 42 bulb/25 watt chandelier and I'd like to install a dimmer switch. I would need a switch that can handle 1050 Watts correct? Does such a switch exist? The highest I've seen is rated at 1000 Watts. Also I should mention that the wiring is knob and tube and I know that heat is a concern. Anything I should be worried about.
Thanks in advance for the advice!
thearchitect is offline   Reply With Quote
Old 03-03-2013, 07:12 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 390
You would need a 1500 watt dimmer, but you will not like the looks of them.
They have fins that sit outside the box.
jbfan is online now   Reply With Quote
Old 03-03-2013, 07:14 PM   #3
Rewards Points: 13,456
I would wonder why the old knob and tube has not been replaced with new romex.
A rewiring job is about 50 years over due.
But that's my own opinion.
Old 03-03-2013, 07:18 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't know what the current chandelier replaced, but the new one draws almost 9A. This is most likely a 15A circuit and may cause the circuit to trip.
Old 03-03-2013, 08:11 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
install 15 watt lamps, save yourself the headache...
Old 03-04-2013, 05:36 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,180
Even better use 7w CFL's,
they make them in all the fancy and miniture sizes now !
dmxtothemax is offline   Reply With Quote
Old 03-04-2013, 05:42 PM   #7
E2 Electrician
Attachment 66759
Yeah, but are they dimmable? A lot of those dont play nice....
Old 03-04-2013, 08:19 PM   #8
Rewards Points: 12
Thank you all for your replies!
Upon further inspection it actually looks like MC cable?...not knob and tube. The wires are in insulated in a rubber/plastic type sheathing, then in a woven fabric, then in a thicker fabric/rubber type insulation. Pic below...
Back to the dimmer in question...
Has anyone had any experience with a Lutron C-1500?
http://www.lutron.com/en-US/Products.../Overview.aspx
Again...thank you all for your helpful replies!
Old 03-04-2013, 08:46 PM   #9
k_buz's Avatar
That is knob and tube.
Old 03-05-2013, 09:43 PM   #10
Rewards Points: 12
Ahhhh yes. Well I believe I have sufficiently shown my inexperience with these matters and have thrown in the towel to call on a professional for help.
If I may, one last question before I hang up my tool belt...
Is knob and tube generally even able to handle a fixture putting out 1050 watts or is this not a good omen? I'd like to have some idea so I can either ship, yet another, fixture back to China or leave this puppy up.
Thanks again all!
Old 03-05-2013, 09:57 PM   #11
Have a look at the size of the fuse for that circuit,
this will give you an idea what it can handle.
All this depends on it still being in good condition.
And be aware that there are many rules reguarding K & T,
you cannot add to, modify or extend K & T.
If it is still working and safe you can continue to use it.
Many electricains choose to not touch any K & T.
Instead they will choose to run a new circuit.
Due to liability issue's.
Tags
dimmer , electrical , knob and tube , switch
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 05:58 PM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 09:51 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
