Old 03-13-2011, 04:26 PM   #1
Dimmer switch not working
We installed a new light fixture and the dimmer switch which was working no longer works. Is there a special way to hook up the new light fixture to the ceiling housing unit.
DebbieLook is offline   Reply With Quote
Old 03-13-2011, 05:32 PM   #2
Just call me Andrew
What kind of bulbs are in the fixture? Does the dimmer turn the light on/off and just not dim, or does the light not turn on at all?
Andrew
secutanudu is offline   Reply With Quote
Old 03-13-2011, 06:24 PM   #3
Make sure the bulbs work, most dimmers dont work without a load on it. What kind of dimmer?
killadelphia is offline   Reply With Quote
Old 03-13-2011, 08:57 PM   #4
Licensed electrician
You can test your wiring by temporarily replacing the dimmer with a regular switch to see if the fixture works.
Old 03-13-2011, 09:03 PM   #5
That works also^. If no extra switch is available you can wire nut the feed and.switch leg together. That also will show if the light works
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
new bathroom dimmer / fan switch captain caveman Electrical 1 09-18-2009 01:39 PM
Installing of SwitchLinc Dimmer (2476D) dlp_710 Electrical 8 08-07-2009 02:31 PM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-17-2007 12:44 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
