-   -   Dimmer switch not working (http://www.diychatroom.com/f18/dimmer-switch-not-working-98239/)
DebbieLook 03-13-2011 03:26 PM
We installed a new light fixture and the dimmer switch which was working no longer works. Is there a special way to hook up the new light fixture to the ceiling housing unit.
secutanudu 03-13-2011 04:32 PM
What kind of bulbs are in the fixture? Does the dimmer turn the light on/off and just not dim, or does the light not turn on at all?
killadelphia 03-13-2011 05:24 PM
Make sure the bulbs work, most dimmers dont work without a load on it. What kind of dimmer?
Jim Port 03-13-2011 07:57 PM
You can test your wiring by temporarily replacing the dimmer with a regular switch to see if the fixture works.
killadelphia 03-13-2011 08:03 PM
That works also^. If no extra switch is available you can wire nut the feed and.switch leg together. That also will show if the light works
