Dimmer Switch Blowing Out - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 09:34 PM   #1
Dimmer switch blowing out
I'm having a problem with my pot lights blowing out my dimmer switch as soon as I turn on the breaker, breaker doesn't blow but the switch does. Could it be possible that the lights are not compatible with a dimmer switch and will require just a straight on off switch. I dont know any of the details about the lights as they were already installed but were never hooked up. Have checked all the wiring and everything looks hooked up properly, and they are on their own breaker direct from the panel
billybigrig is offline   Reply With Quote
Old 04-08-2013, 10:26 PM   #2
Master Electrician
Rewards Points: 3,870
Are the fixtures line voltage or low voltage? Low voltage fixtures require a magnetic or electronic dimmer depending upon what type they are.
brric is offline   Reply With Quote
Old 04-08-2013, 11:45 PM   #3
Electrical Contractor
kbsparky's Avatar
Maybe you have the dimmer wired as a dead short?
First thing to do is replace the dimmer with a standard wall switch, and ensure that everything is working properly. Do the lights stay "on" with the switch "off" and then blow the breaker when the switch is turned "on"?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
oh'mike (04-09-2013)
Old 04-09-2013, 12:18 AM   #4
not sure they were already in the ceiling when moved in
Old 04-09-2013, 12:21 AM   #5
lights are off when switch is off when you turn the switch on lights come on and the get a loud pop and bang and lights go out switch is dead and breaker is still not tripped
Old 04-09-2013, 12:25 AM   #6
" Euro " electrician
frenchelectrican's Avatar
First thing of all did you installed those recessed luminarie or not ?
Second thing try to unscrew all the lamps ( light bulbs ) out of the recessed luminaires and try it again if that kick out if not then you have issue with concat on one of the socket.
But if do kick out without lamp then you have wiring issue either wrong connection or a hot conductor touching the housing ( this part can happend often if not carefull when you close the cover back on )
And if you have the dimmer switch there after a hard short circuit the dimmer is toasted so you will end up replace it but before you replace it use the simple toggle switch to trobleshooting first to make sure all the recessed luminaries are working properly before you replace the dimmer.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
billybigrig (04-09-2013)
Old 04-09-2013, 12:34 AM   #7
kbsparky's Avatar
I have seen bad insulation sensors do this. Loud pop, breaker trips, etc.
IF those sensors have gotten wet, they are ruined.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
billybigrig (04-09-2013), frenchelectrican (04-09-2013)
Replacing a dimmer switch with a regular switch for a ceiling fan RP DeMars Electrical 0 04-18-2012 03:25 PM
Chandelier and dimmer switch compatibility .Capstone Electrical 2 11-04-2011 05:01 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
