HI, Im not very big on electrical parts but i would like to know if anywhere supplies a 2 gang switch where one gang is a dimmer and one gang is a switch. Does any such thing exist.
I have two lights connected to one wall plate. I would like one light on a dimmer and one on an ordinary switch is this possible on a single wall plate.
Yes both have just on off switches on a wall plate. just want to put one on a dimmer but cant seem to find a wall plate that has one dimmer and one seprate switch
Your not going to find a split dimmer rated for a 1000 watts...
what I would do then is make the box a 2 gang, this way you can have the halogen on a single pole switch and the other load on a single pole dimmer... looks like your only choice.
No problem, hope it works out for you. Cutting in a 2gang should not be too much a problem with a little patience.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
