Dimmer Switch For 12 Volts - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 04:08 PM   #1
Rewards Points: 113
dimmer switch for 12 volts
I have no idea how a 110 volt AC dimmer switch works so I ask this: Can I use a 110 volt dimmer light switch to regulate a 12 volt current that is 3 to 6 amps?
Captflx is offline   Reply With Quote
Old 04-02-2009, 04:56 PM   #2
Remodeling Contractor
Yes and No .. First the transformer for this needs to be a dimming transformer. And it will only work for some types of electronic units.
Old 04-02-2009, 05:26 PM   #3
AC?
to a resistive or lamp load?
You're controlling applied voltage rather than regulating current.
The control range will be narrower, at least. You lose 1v or so in the Triac, which isn't noticed in a 120v circuit.
A 600w dimmer may be limited by the heat dissipation or the current rating (600/120 = 5A) of the Triac.
Plus, I think the triggering circuit is looking for 120v. When the control is full on with 12vac applied, you may only get a 10% duty cycle.
http://www.learnabout-electronics.or...cs-diacs02.gif
This circuit ^ runs on 230vac [50 Hz?] but for 120vac 60 Hz you only need to change one or two component values.
If you go inside the dimmer and change the value of R you might get it to sort of work at 12vac.
Old 04-02-2009, 05:44 PM   #4
So what we are saying is that you need a dimming transformer and a dimmer made to work with this setup. I use these in my kitchen. Touch and hold the refrigerator and the low voltage Xenon under cabinet lights dim.
Old 04-02-2009, 07:16 PM   #5
Rewards Points: 820
You should use a Variac instead of a dimmer. Plug the low voltage transformer into the output of the variac. A variac is not an electronic device, it's purely electrical. All it is, is a variable transformer. Some can also boost the line voltage as well as lower it.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 04-02-2009, 08:51 PM   #6
Rewards Points: 113
Thanks all. Would it make a difference in any of these answers if I put the dimmer switch between a 12 volt battery and a 12 variable speed drill motor?
Old 04-03-2009, 11:14 AM   #7
Triacs can't control DC. For this application, if you want low speed torque you'd need a PWM speed control.
Old 04-03-2009, 02:54 PM   #8
Rewards Points: 113
Thanks.
I'll invest in one made for 12 volts DC.
Old 04-03-2009, 03:03 PM   #9
Thanks.
You could cannibalize a discarded variable speed drill, but this speed control module might be the first thing to fail (next to the battery pack).
The manuf. may want a stiff price for a replacement module.
Old 04-03-2009, 04:30 PM   #10
Why would you want to put a voltage limiter between a battery and a 12 vdc variable speed motor?
hayewe farm is offline   Reply With Quote
Old 04-06-2009, 01:55 PM   #11
Originally Posted by ijkl203 View Post
Louis Vuitton handbags,Louis Vuitton purses,Louis Vuitton handbag,Louis Vuitton luggage sells very hot on the world. here. Louis Vuitton began manufacturing trunks in Paris in 1854, and the company he started went on to become one of the world's most famous makers of luxury goods, known especially for its designer luggage pattern: a beige-on-chestnut monogram, "LV." Vuitton's high-quality travelling trunks were such a hit that he had to expand his factory within a few years, relocating to Asni??res in 1860. As the years went by the Vuitton line gained international recognition, thanks in part to a bronze medal at the 1867 World's Fair and a gold medal at the 1889 World's Fair, both held in Paris. After Louis died in 1892, his son, Georges, took the company to new heights, developing what is recognized as the first "designer label" on a product. (Widespread copying of Vuitton patterns pushed Georges to design the distinctive "LV" monogram.) Vuitton's luggage company has since become a world leader in luxury consumer goods, with products that include travel books, perfume, distilled spirits and designer clothing. Louis Vuitton handbags Wholesale
Did this guy \/ have one?
http://images.google.com/images?hl=e...mages&aq=f&oq=
Dimmer Switch Vandiyan Electrical 21 12-15-2008 08:23 PM
Dual Dimmer Switch Headache! BrumGuy Electrical 3 12-02-2008 03:39 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
