Old 02-18-2006, 02:24 PM   #1
Dimmer questions...
I have a light in the kitchen that is currently connected to two wall switches.
I am going to be taking that one light out and wiring in 5-7 recessed cans.
Can I swap out the two normal switches with dimmers?
This shouldn't be a problem will it?
Thanks in advance!
davo420 is offline   Reply With Quote
Old 02-18-2006, 03:38 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Dimmer questions...
No problem. Be sure to use a 3-way dimmer and be very clear on how the old switch was wired.
Old 02-18-2006, 03:41 PM   #3
Dimmer questions...
thx
Can you plz explain?
to make sure I wire the dimmer one's the same?
Old 02-18-2006, 04:36 PM   #4
Dimmer questions...
Yes. Be sure you identify the "common" and the two travelers.
Old 02-18-2006, 05:43 PM   #5
Dimmer questions...
Thx Petey.
Will both work as active dimmers?? Only one?
Old 02-18-2006, 10:14 PM   #6
Electrical Contractor
Dimmer questions...
They do make dimmers that will work from both locations. I have not used them yet. I still use the dimmer in one location.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-18-2006, 10:28 PM   #7
Dimmer questions...
Right, what JB said.
The multi location dimmers are generically know as "smart" dimmers. They are more money for each and you typically must use one in every location. As opposed to a typical 3-way dimmer which you can only use in one location.
Old 02-18-2006, 10:46 PM   #8
Dimmer questions...
Thanks guys!
This place is great.:D
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
OK to user a dimmer with ceiling light? FreeCashBack.co.uk Electrical 2 06-19-2005 10:16 PM
