Dimmer Not Working (much At All) - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2008, 12:21 PM   #1
Gusaroo's Avatar
Dimmer not working (much at all)
I just swapped out a switch for a 600 watt dimmer. The switch was for a 6 bulb dining room chandelier. The fixture has (6) 40w small candle bulbs.
The dimmer does not make the fixture dim much at all. What is going on here?
BTW, the dimmer switch I replaced is a three way, if that means anything. The other switch for this circuit is not a dimmer.
Gusaroo is offline   Reply With Quote
Old 03-15-2008, 12:29 PM   #2
In every home center, there are three different types of dimmers - incandescent, magnetic and electronic - and the single or 3-way model in each as well. Assuming it's an incandescent, 6-bulb fixture, did you buy and install the correct type and model, i.e. incandescent, 3-way dimmer? If you did buy and install the correct one, review your wiring of it carefully.
End Grain is offline   Reply With Quote
Old 03-15-2008, 12:32 PM   #3
Gusaroo's Avatar
I believe it was the correct one, I am usually pretty anal about buying this stuff. Of course, I already thru the box away. I am going to take the cover off the light and see if the switch is labeled to double check....
Old 03-15-2008, 12:38 PM   #4
Gusaroo's Avatar
It says "For permanent incandescent fixtures. 120 vac, 60 hz"
Its a Lutron TG-603P Could it be defective?
http://www.lutron.com/instructions/030521.pdf
I am assuming my wiring is correct, it was pretty straight forward, I took out the non dimmer three way and installed this one directly the same way. It does dim the fixture a little bit and it works correctly with the other three way switch in this circuit.
Old 03-15-2008, 12:47 PM   #5
Anything is possible (defective) but I would suggest you review the wiring that you did first, before returning it. If it's installed correctly, then you should be able to turn the light on and off from either wall location respectively, with absolutely no issues. If that's working properly, then perhaps the dimmer part of it actually IS defective. If you cannot control the light properly from either wall location, then you probably connected the common wire to the incorrect lead. Take your time and review the work you did.
Old 03-15-2008, 01:09 PM   #6
If it is wired correctly (you have tested it on/off with both locations twice) and the connections are tight, you have a defective dimmer.
It happens
220/221 is offline   Reply With Quote
Old 03-15-2008, 02:27 PM   #7
Gusaroo's Avatar
no, it works properly, just does not dim as expected when I slide the adjuster. Ill try another switch. thx guys
Old 03-25-2008, 03:23 PM   #8
Gusaroo's Avatar
Swapped out the switch, it now works. Damn Home Depot sold me a defective switch... I am just glad it was something that simple.
THX GUYS!!
Old 03-25-2008, 03:45 PM   #9
Licensed Pro
Betcha HD had already sold that dimmer once before and had it returned as defective, then had it mysteriously reappear on the shelf. That's why whenever I return a defective item, I mark up the packaging so it can't be put back out.
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Changing A Dimmer badgerbrian1974 Electrical 8 02-17-2008 10:15 PM
Touchpad/remote dimmer dan76 Electrical 1 02-17-2008 09:10 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
