Dimmer Load - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 08:43 PM   #1
Rewards Points: 141
dimmer load
I've installed a few dimmer switches, slide style control on the side of the normal looking up and down toggle switch, but always for a one light-bulb fixture. I want to install one that will control a bathroom vanity light with four light-bulbs. In it I'm using four CFL bulbs with lighting output of 60 watts per bulb, and so even less actual wattage use. The dimmer switch IS CFL dimmer approved. My question is: Is there a load maximum for the dimmer? Can I use it to dim the four bulbs in the one fixture? On the package it says 150 W for CFL, is that the total load or the maximum per bulb? Thanks!! (I could not find this info on the package/instructions.)
DiegoJames is offline   Reply With Quote
Old 02-27-2012, 08:46 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Dimmers range from 600 watts up, so you should be fine.
What is the model # of the dimmer?
jbfan is online now   Reply With Quote
Old 02-27-2012, 09:00 PM   #3
Rewards Points: 141
dimmer load to jbfan
Lutron C.L Dimmer, TGCL-153PH-LA. It says 600w on front package which I thought by the way the print is laid out referred only to the incandescent specs, and then 150w written after the CFL. But yeah, I guess it's load is 600w which as you say sounds fine?
Old 02-28-2012, 11:02 AM   #4
Do your CFLs actually consume 60W each, or are the "60W equivalent" (typically 13W consumption)? If the latter, you should be fine.
The dimmer may have a lower rating for CFLs, because most CFLs have a very poor power factor, meaning the current they draw is somewhat time-shifted from the 60Hz sinusoidal voltage. They are not a resistive load like incandescents, and actually draw their current in short spikes.
If the load is too much, you'll probably hear the dimmer buzz or "ring" slightly.
jbs11 is offline   Reply With Quote
Old 02-28-2012, 11:56 AM   #5
Rewards Points: 81
Many dimmers also have a minimum wattage. For instance, the lutron 600 watt dimmers I recently installed clearly warn not to use them for loads less than 45 watts.
JeepNick is offline   Reply With Quote
4 Way Dimmer Question mjkpainting Electrical 1 01-29-2012 07:11 PM
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 03:00 PM
1000W Dimmer with 715W load getting beyond warm? Badfish740 Electrical 5 05-02-2011 06:23 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
