-   -   Dimmer Installation (http://www.diychatroom.com/f18/dimmer-installation-17403/)
rjl24 02-20-2008 05:54 PM
Dimmer Installation
1 Attachment(s)
I have a two gang box with originally had a 3 way switch and a single pole switch. In the process of attempting to replace the single pole swith with a dimmer, we are now totally lost!
The box contains 5 main groups of wires (I have attached a rudimentry diagram)
group 1: one red wire, one white wire, one black wire , and a copper ground wire.
group 2: one black wire (hot),one white wire, and a copper ground wire
group 3: one black wire, one white wire, and a copper ground wire
group 4: one black wire, one white wire, and a copper ground wire
group 5: one black wire, one white wire, and two copper ground wires
Because of the single hot black wire, I am assuming the single pole switch drew power from the 3 way switch.
Has anyone wired anything similar?
thanks!
chris75 02-20-2008 05:56 PM
Why dont you just install the dimmer in place of the single pole and not take apart every splice in the box?
joed 02-20-2008 06:03 PM
How much it have you taken apart and how much is still the way it was before you started?
chris75 02-20-2008 06:09 PM
YOU need to find out where the wires go and remake the splices accordingly, This isnt something you can just ask someone off the street... :)
220/221 02-20-2008 07:43 PM
There are a couple of ways this might go. It all hinges on your group 1 wires.
If you took them apart, wire nut group 2 thru 5 whites back together.
Turn the power on and CAREFULLY touch the hot black wire to the other black wires one at a time to determing whick ones go to your 2 diferent sets of lights (operated by the original single pole and 3 way). I WILL make a slight arc spark when you touch them and the lights will go on.
Instead of working it hot, you should turn off the breaker, attach the blacks with a wire nut (one at a time) and tun it on. You will have to run back and forth about ten times but it will be safer....more safe...whatever.
Identify these black wires as your 2 switch legs.
There are many ways that the 3 way might be wired so if you get this far and determine that both switch legs are in this box I will guide you the rest of the way. The switch leg MAY be in the other 3 way box.
Be careful.
