dimmer on gfi circuit
Hello All. I am a new member and haven't been able to find my exact problem in the electrical forums.
I have installed a new circuit for a bar and track lights above it. In a 2 gang box, I installed a gfci outlet for bar power, and a Lutron D600 dimmer to control the track light above the bar. I connected one dimmer black wire to the brass outfeed terminal of the gfi and the other to the black going up into the ceiling box for the light. The white wire from the ceiling box is connected to the white outfeed terminal of the gfi.
When I first turned the breaker on, the lights worked and were dimmable by the rotary switch. After I had turned the breaker back off to align the gfi and dimmer holes for the faceplate, and turned the breaker back on, the lights won't light. The gfi didn't blow, nor did the breaker. I have pushed the shaft in and clicked it several times, and rotated the shaft throughout it's range while repeatedly turning the switch off and on.
I thought maybe I had a bad dimmer, so i exchanged it for a new one at Lowe's. The same sequence of events happened. Does anyone know if you aren't supposed to connect a dimmer on the outfeed side of a gfci? I'm using GE 45 watt r20 bulbs. They aren't listed on Lutron's compatibility list, but that's all I know about them. Maybe they are the problem. Any ideas? Thanks. Jim
