Dimmer Causing Interference - Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2008, 08:57 PM   #1
Dimmer causing interference - Help
I've purchased a dimmer switch (3 way) to control some recessed cans (Halo) in my basement. However, the dimmer switch hums and when on causes EMI to travel along the coax feeding my HDTV. With the switch turned off the EMI goes away. Is it a faulty dimmer? I swapped it out for a non-dimming switch, and the EMI is not a problem when the lights are on.
Thanks!
scottmatt is offline   Reply With Quote
Old 04-18-2008, 05:38 AM   #2
Thanks!
Make sure your dimmer is sized to handle the load. Dimmers are sized based on the load (watts) they need to handle.
Jeff
ElectricianJeff is offline   Reply With Quote
Old 04-18-2008, 06:23 AM   #3
Jeff
Thanks Jeff. There are a total of 6 cans on that switch (all using Low-E CFL's 14w usage for 65w equivalent). So to calculate the load, do I just multiple the amount of cans by the wattage of the cfl's?
Old 04-18-2008, 06:33 AM   #4
Licensed electrician
Rewards Points: 1,766
Are these dimmable CFL's? Most are not.
Old 04-18-2008, 07:23 AM   #5
The CFL's currently installed are not...but ultimately (after construction) I plan to install Dimmable CFL's (expensive buggers!).
I thought that might be the problem, but even when the dimmer is set to full power, the problem persists.
Old 04-18-2008, 09:08 AM   #6
Pull the CFL's and put in some incadesants. You problem may go away.
Jeff
Dimmer not working (much at all) Gusaroo Electrical 8 03-25-2008 02:45 PM
Changing A Dimmer badgerbrian1974 Electrical 8 02-17-2008 09:15 PM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-16-2007 11:44 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
