Dimmer-aluminum Ground Along With Existing Copper Ground. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2009, 09:04 PM   #1
Smile
dimmer-aluminum ground along with existing copper ground.
Just installed two dimmers side by side in a double wall box. They work fine. Each dimmer has a ground wire. I want to wind both ground wires (aluminum) around one screw located on the left side of a metal plate at the back of the wall box. The wall box already has a copper ground wire wound around a screw on the right side of the same metal plate at the back of the wall box. I don't think this would be a problem but want to be sure.
By the way I have other copper to aluminum wires marrited with the correct connectors. I just want to know about the ground wires. Thanks.
scottie is offline   Reply With Quote
Old 09-24-2009, 09:29 PM   #2
Licensed electrician
Rewards Points: 1,038
The wire from the dimmer is not aluminum if the dimmers are new.
You can only put one wire under a screw. Join the 2 dimmer grounds to a short piece of copper and then attach the copper to the new ground screw.
Old 09-25-2009, 07:43 AM   #3
Electrical Contractor
kbsparky's Avatar
You are confusing a tinned copper conductor with aluminum.
That ground wire that comes attached to the dimmer is copper, and can be safely wire-nutted to a copper pigtail from the box green screw.
-KB
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 06:22 PM
Panel ground questions Joe F Electrical 12 08-05-2008 10:48 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
rewiring all existing wiring mcvane Electrical 7 02-25-2008 06:38 AM
