Dimmer On A 3-way Switch Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 01:15 PM   #1
raylo32's Avatar
Rewards Points: 1,294
dimmer on a 3-way switch circuit?
I have a large room that has a switch at each of 3 doors that contol the overhead lights. Is it possible to put a dimmer on this circuit, say by replacing one of the switches with a dimmer switch, and still have the other switches work for on/off? If so, do I need a special type of dimmer?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 09-17-2013, 01:37 PM   #2
can you presently turn the lights on/off at any of the three doors?
itsnotrequired is offline   Reply With Quote
Old 09-17-2013, 01:48 PM   #3
raylo32's Avatar
Yes...
Old 09-17-2013, 01:56 PM   #4
you have a four-way switch and two three-way switches. electrically, the four-way switch will be 'between' the two three-way switches. you can replace either of the three-way switches with a dimmer and on/off will work at the remaining switches. only catch is that if someone sends the dimmer to zero, the on/off function won't work at the other locations.
depending on your wiring, you may be able to replace all three switches with multi-location dimmers. these let you do on/off AND dimming at all three locations.
Old 09-17-2013, 01:57 PM   #5
Rewards Points: 1,480
Good question. I was thinking about doing this in my kitchen. I have a three way though because I have two switches.
mikegp is offline   Reply With Quote
Old 09-17-2013, 02:00 PM   #6
raylo32's Avatar
Sounds good. I guess I'll have to pull the switches to see which one is the 4-way and which are the 3-ways. I already know which one I'd like to have the dimmer on so that probably means it'll turn out to be the 4-way. :-/
Thanks for the help!
The Following User Says Thank You to raylo32 For This Useful Post:
oh'mike (09-17-2013)
Old 09-17-2013, 05:26 PM   #7
Rewards Points: 348
If you don't mind Decora size devices, look at the Lutron Maestro line. You get the main dimmer and then use slaves at the other locations, but all locations can dim. Only the main one has the LED indicators though.
herdfan is offline   Reply With Quote
Old 09-17-2013, 06:56 PM   #8
DIY staff
Rewards Points: 7,174
Just a small tip----do not ever install a dimmer with the power ON---one little mistake and you can fry the switch--the new ones don't take shorting out and survive. (don't ask me how I learned that,please.)
jbfan (09-18-2013)
Old 09-18-2013, 08:34 AM   #9
this is exactly what i used in my basement. it is a large, open room and i wanted to be able to dim at both ends. saw the 3-way 'dimmers' at the big box store and realized it was simply a dimmer switch with a separate on-off switch for the other location. after some digging, came across the meastro stuff. perfect!
Old 09-18-2013, 08:43 AM   #10
PoleCat's Avatar
Rewards Points: 1,652
Yup,yup. My cousin fried his new three way dimmer. Even if you are careful and don't make a mistake a little arc that happens when the last wire is nutted will fricassee the electronics.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
oh'mike (09-18-2013)
Old 09-18-2013, 06:16 PM   #11
Rewards Points: 1,476
You need to be aware that these will not work with LED bulbs.
ktkelly is offline   Reply With Quote
Old 09-18-2013, 06:28 PM   #12
Rewards Points: 348
Sure they do. You just need to get the models with the CL in the model #.
It is probably best if you use the bulbs on this list.
Old 09-27-2013, 05:13 PM   #13
raylo32's Avatar
Got my dimmer installed today... it is a Lutron with a big on-off rocker and a slide dimmer. No cfls or leds yet to test but works great with my regular can lights with incandescent bulbs. Thanks for the tips guys.
Old 09-27-2013, 05:35 PM   #14
raylo32's Avatar
oh'mike (09-27-2013)
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Replacing a Dimmer switch with a standard switch zenox Electrical 4 07-26-2012 08:58 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 10:57 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
