Dimmer Of 12v Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 05:13 PM   #1
Dimmer of 12v fixture?
Hi everyone. I've bought an IKEA 12v light fixture for my study and I'd like to use a dimmer with it. My question is : can I use a standard 120V dimmer with a 12v fixture? If not, are other dimmers available that will work properly?
It being an IKEA fixture, I have zilch info on it (type of transformer used, etc).
Thanks for the info!
clemon03 is offline   Reply With Quote
Old 10-06-2009, 05:18 PM   #2
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 10-06-2009, 05:56 PM   #3
let me clarify - The fixture is ceiling mounted, and contains its own transformer. Regular household power runs from the switch to the fixture box, so there's nowhere to insert a 12v dimmer between transformer and light fixture.
Will a 120v dimmer at the switch work properly/safely?
Old 10-06-2009, 09:14 PM   #4
at least one company makes a dimmer that can handle a transformer/lamp arrangement
http://www.crestron.com/downloads/pd..._switching.pdf
Lutron probably makes something also.
Old 10-06-2009, 11:04 PM   #5
Rewards Points: 1,016
If the transformer in the light fixture is dimmable, then yes. Probably check with the manufacturer of the light fixture. If the built-in transformer is not dimmable, perhaps explore changing it (either the transformer or the entire fixture) out for one that is.
Old 10-07-2009, 11:27 AM   #6
Thanks guys! My local HD electrical dept guy has steered me in the right direction here as well. I have discovered that the transformer in the fixture is an electronic version versus magnetic, so I'll pick up a low-voltage electronic dimmer today and give that a whirl.
Cheers,
Old 10-07-2009, 11:42 AM   #7
Rewards Points: 58
Cheers,
Keep a fire extinguisher handy.
Old 10-07-2009, 11:46 AM   #8
That;s only a helpful comment if you can explain why......
Old 10-07-2009, 01:38 PM   #9
Cheers,
I thought you were going to dim the 120vac upstream of the 'former.
Old 10-07-2009, 01:48 PM   #10
Sorry - I'm being obtuse again....
Leviton produces dimmers specifically made for low-voltage lighting. They connect to the 120v household current like a normal dimmer switch. Two varieties are made - one for electronic transformers and one for magnetic transformers.
THe kicker is that they retail for around $40CAD! OUCH!!! At theat price I can replace the damned 12v light fixture with a 120v one! That's not happening right now, so I'll live without the dimmer for a while......
Old 10-07-2009, 06:09 PM   #11
If you don't want variable dimming you can use a power resistor or long length of skinny wire on the 12v side to dim the thing, for a lot less than $40.
Old 10-07-2009, 06:26 PM   #12
Thumbs up
I like the witty reply! But, seriously. There are dimmers designed specifically for that purpose. It must state so on the package. (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
Help with dimmer switch and ceiling fixture Janice MacDonald Electrical 25 10-12-2008 08:04 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
