Dimmed Lights Dim More With A Power Draw - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 03:59 PM   #1
Rewards Points: 150
dimmed lights dim more with a power draw
I've always wondered why when you have a light turned down on a dimmer and something like the fridge or an AC compressor kicks on they dim a little more.
I assume this is normal since I've noticed it for years in multiple homes.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 02-22-2009, 05:11 PM   #2
Rewards Points: 1,512
When a large motor is in operation, an uncanny kind of "voltage drop" occurs where the voltage and current get out of phase.
You would almost need a Ph.D. in electrical engineering to understand this phase relationship. It is not related to the difference between single phase and 3 phase power.
A process called "power factor correction" puts the voltage and current back in phase. This is typically accomplished by putting a big capacitor between hot and ground. The size of the capacitor should depend on the average load of motors and other inductive devices, or more or fewer capacitors switched in as needed.
For household use this phase difference is usually not much but some dimmers are sensitive to it and produce greater or less dimming when the phase changes.
Also the normal voltage drop that occurs when the overall load is increased might translate into a more noticeable difference in the brightness of the lamp at that particular level of dimming.
3 Way Switch Draw additional Power? mattyd Electrical 15 03-24-2008 01:36 PM
need power for 120v to 12v undercabinet lights robin hood Electrical 2 02-26-2008 03:43 PM
wiring up two lights to one power supply divy Electrical 6 02-11-2008 05:49 AM
Pulling power for new lights TerryL Electrical 2 10-26-2006 08:08 PM
power source for recessed lights Jackman Electrical 1 09-18-2006 07:30 PM
