Dimmable Switch Buzzes - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2012, 07:59 AM   #1
Question
Dimmable switch buzzes
So I have a dimable switch that I wired to 4 cam lights. The lights don't buzz, but the switch buzes really loud. What is the problem?
altja is offline   Reply With Quote
Old 09-24-2012, 09:20 AM   #2
what is "cam lights"? camera lights? recessed canister?
do you have CFL bulbs powered by that switch?
allthumbsdiy is offline   Reply With Quote
Old 10-06-2012, 02:19 PM   #3
I have recessed lights with CFL bulbs?
Old 10-06-2012, 09:20 PM   #4
Missouri Bound's Avatar
Is that dimmer specified to work with CFL bulbs...and are those CFL bulbs listed as dimmable? Two very important factors.
Do you want it your way or the right way?
Old 10-06-2012, 09:24 PM   #5
Rewards Points: 13,270
If there not it's not going to work.
Old 10-06-2012, 09:27 PM   #6
Civil Engineer
Rewards Points: 4,566
There are several different types of dimmers, some of which are not intended to be used with cfl lights or led lights. Certain low cost dimmers use triacs and are inherently noisy. Best to check if the specific dimmer you installed is rated for the specific lights you have.
Daniel Holzman is online now   Reply With Quote
Old 10-07-2012, 12:52 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,102
Most dimmers will buzz to some extent,
It could be the triac itself, or most likely
it is the supressor choke.
Cheaper dimmers tend to buzz more.
Check nothing is loose inside the dimmer.
Sometimes some silicon can reduce buzzing,
but it must be neutral cure.
Potting is the term you Americans use I beleive.
dmxtothemax is offline   Reply With Quote
Tags
dimmers , wiring
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
