-   -   Dimmable switch buzzes (http://www.diychatroom.com/f18/dimmable-switch-buzzes-157818/)
altja 09-24-2012 06:59 AM
So I have a dimable switch that I wired to 4 cam lights. The lights don't buzz, but the switch buzes really loud. What is the problem?
allthumbsdiy 09-24-2012 08:20 AM
what is "cam lights"? camera lights? recessed canister?
do you have CFL bulbs powered by that switch?
altja 10-06-2012 01:19 PM
I have recessed lights with CFL bulbs?
Missouri Bound 10-06-2012 08:20 PM
Is that dimmer specified to work with CFL bulbs...and are those CFL bulbs listed as dimmable? Two very important factors.:yes:
joecaption 10-06-2012 08:24 PM
If there not it's not going to work.
Daniel Holzman 10-06-2012 08:27 PM
There are several different types of dimmers, some of which are not intended to be used with cfl lights or led lights. Certain low cost dimmers use triacs and are inherently noisy. Best to check if the specific dimmer you installed is rated for the specific lights you have.
dmxtothemax 10-06-2012 11:52 PM
Most dimmers will buzz to some extent,
It could be the triac itself, or most likely
it is the supressor choke.
Cheaper dimmers tend to buzz more.
Check nothing is loose inside the dimmer.
Sometimes some silicon can reduce buzzing,
but it must be neutral cure.
Potting is the term you Americans use I beleive.
