Dimmable Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 06:29 AM   #1
Rewards Points: 81
Dimmable Receptacle
What are the codes around dimmable receptacles?
The only dimmable receptacle I can find is by Lutron
Is it code that a dimmable receptacle require a special plug to use? I find it odd that the special plug by Lutron is 2 prong vs. the receptacle that is 3 prong
LarryM is offline   Reply With Quote
Old 06-07-2012, 06:38 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
You are not allowed to dim a receptacle. I guess Lutron got around this by making the plug proprietary.
Speedy Petey is online now   Reply With Quote
Old 06-07-2012, 06:47 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
I thought that having a dimmer on a receptacle was a code violation. It is dangerous because you could plug something other than a lamp into it: a vacuum cleaner for example.
The receptacle looks like a stand 15 amp receptacle lay-out.
Lamps typically only have a 2 blade plug.
Found some info:
Apparently these receptacles have a lockout feature that will reject a normal plug and will only allow the insertion of the plug you show. This means you have to cut off the regular plug to install the special one and you will no longer be able to plug the lamp into a regular receptacle.
http://files.lutron.com/hwi/TRG/366-...eceptacles.pdf
Coastal South Carolina
Old 06-07-2012, 07:03 AM   #4
Rewards Points: 81
Found some info:
Yeah I'm not too thrilled about cutting the cord of a $900 fiber optic illuminator but it should be an easy to do.
Right now I am leaning against the dimmer and will see what my end product is and decide from there.
Old 06-07-2012, 07:13 AM   #5
A "Handy Husband"
rjniles's Avatar
Use a plug in dimmer in a standard receptacle and use the existing plug on your lamp.
Old 06-07-2012, 08:36 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Where is that written?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-07-2012, 08:40 AM   #7
Code05's Avatar
Rewards Points: 1,104
404.14(E) Dimmer Switches. General-use dimmer switches shall
be used only to control permanently installed incandescent
luminaires unless listed for the control of other loads and
installed accordingly.
Code05 is offline   Reply With Quote
The Following 3 Users Say Thank You to Code05 For This Useful Post:
kevinp22 (06-07-2012), LarryM (06-07-2012), Speedy Petey (06-07-2012)
Old 06-07-2012, 08:42 AM   #8
electures's Avatar
Thanks.. Never saw that one.
Old 06-07-2012, 09:07 AM   #9
Code05's Avatar
No prob, the violation I see the most is people trying to use the wrong type of dimmer on fan loads.
Old 06-07-2012, 03:01 PM   #10
Rewards Points: 81
Sounds like a plan but I am not using it for a lamp. I am using it to dim a fiber optic star ceiling and I would like to control it by remote control using the Lutron Spacer System dimmers.
Old 06-07-2012, 04:28 PM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Can you hard wire the optic driver?
Old 06-07-2012, 06:35 PM   #12
Rewards Points: 81
I don't think so, the company I am working with made no mention of it.
Really bad web site, but this is the illumintor I am going with http://www.fosi.com/Tech/endlit1.htm
It will come with 2 plugs, one to control the motor which won't be dimmed and one to control the LED bulb
Old 06-08-2012, 09:23 PM   #13
If you are concerned with cutting your cord, put the plug on a short extention cord to test it out.
ttech is offline   Reply With Quote
Old 06-09-2012, 05:21 AM   #14
Rewards Points: 81
Thanks Funny the things you don't think of
Old 06-09-2012, 05:44 AM   #15
E2 Electrician
It will work, but the problem is you will void the UL listing if the driver comes pre installed with a cord and you modify it by cutting the end off..... so you would need to see if you buy a unit that is meant to be hard wired.
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 01:18 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
