Dimmable Fluorescent Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 04:55 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
From my current experience, dimmable fluorescent bulbs are a scam. I replaced 2 regular 65w recessed light bulbs in the kitchen - figuring I'd do a couple at a time since the bulbs are a little pricey. When I dim the circuit, the normal bulbs will still dim all the way down, but the new fluorescent bulbs go from bright, to a little less bright. They don't really "dim." Is it because I have intermixed incandescent and fluorescent bulbs on the same switch, or do they just suck for dimming?
hyunelan2 is offline   Reply With Quote
Old 04-25-2011, 05:55 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
are these CFLs or tubes? And I am assuming that you are using a wall dimmer rated for the purpose?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-25-2011, 07:10 PM   #3
Rewards Points: 1,566
I don't think all CFLs are dimmable.
bob22 is online now   Reply With Quote
Old 04-25-2011, 10:21 PM   #4
hyunelan2's Avatar
Rewards Points: 686
They are the dimmable CFLs made for recessed fixtures. Not all CFLs are dimmable, but these are the ones that are supposed to be, as indicated on the package. It is a standard wall dimmer switch.
Old 04-25-2011, 11:02 PM   #5
Unscrew the incandescent lamps and see if the CFLs function as they are supposed to.
Old 04-25-2011, 11:42 PM   #6
Rewards Points: 746
I've got 3 of the dimmable CFL R30 equivalents. They don't dim all the way down at best maybe 1/2 brightness that's it.
So far 2 years though and no problems. Standard dimmer.
AandPDan is offline   Reply With Quote
Old 04-26-2011, 01:10 AM   #7
" Euro " electrician
frenchelectrican's Avatar
What brand name screw in dimmable CFL you have ??
somecase if you change the namebrand that useally do the trick.
Most the dimmable screw in CFL I know can work with standard dimmer however follow the manufacter instruction very carefull if they stated which type of dimmer swtich to use the standard dimmer or electronique dimmer or others as need to.
We have simuair situation on European side as well some do work and some are not worth a crap.
And make sure you double check with recessed cans luminaires some will not work very well in there due some are IC cans it can get very warm and wreck the CFL controller.
Merci,
Marc
fluorescent screw in bulbs 300zx Electrical 15 10-16-2009 09:05 AM
fluorescent fixture/bulbs december45 Electrical 6 08-22-2009 01:05 PM
Help with: Dimmable Compact Florescent Bulbs millerz1897 Electrical 19 04-06-2009 06:44 AM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 06:51 PM
fluorescent bulbs, worth it? xamplesample Electrical 4 01-19-2009 12:10 PM
