-   -   Dimmable Fluorescent Bulbs (http://www.diychatroom.com/f18/dimmable-fluorescent-bulbs-102687/)
hyunelan2 04-25-2011 03:55 PM
From my current experience, dimmable fluorescent bulbs are a scam. I replaced 2 regular 65w recessed light bulbs in the kitchen - figuring I'd do a couple at a time since the bulbs are a little pricey. When I dim the circuit, the normal bulbs will still dim all the way down, but the new fluorescent bulbs go from bright, to a little less bright. They don't really "dim." Is it because I have intermixed incandescent and fluorescent bulbs on the same switch, or do they just suck for dimming?
Saturday Cowboy 04-25-2011 04:55 PM
are these CFLs or tubes? And I am assuming that you are using a wall dimmer rated for the purpose?
bob22 04-25-2011 06:10 PM
I don't think all CFLs are dimmable.
hyunelan2 04-25-2011 09:21 PM
They are the dimmable CFLs made for recessed fixtures. Not all CFLs are dimmable, but these are the ones that are supposed to be, as indicated on the package. It is a standard wall dimmer switch.
Wildie 04-25-2011 10:02 PM
Unscrew the incandescent lamps and see if the CFLs function as they are supposed to.
AandPDan 04-25-2011 10:42 PM
I've got 3 of the dimmable CFL R30 equivalents. They don't dim all the way down at best maybe 1/2 brightness that's it.
So far 2 years though and no problems. Standard dimmer.
frenchelectrican 04-26-2011 12:10 AM
What brand name screw in dimmable CFL you have ??
somecase if you change the namebrand that useally do the trick.
Most the dimmable screw in CFL I know can work with standard dimmer however follow the manufacter instruction very carefull if they stated which type of dimmer swtich to use the standard dimmer or electronique dimmer or others as need to.
We have simuair situation on European side as well some do work and some are not worth a crap.
And make sure you double check with recessed cans luminaires some will not work very well in there due some are IC cans it can get very warm and wreck the CFL controller.
Merci,
Marc
