Old 10-10-2010, 08:23 AM   #1
Dimmable CFL
I got a kitchen light at one of the big box stores some months ago and just yesterday put it in. The instructions say that it's not a dimmable light. From what I recall, we asked one of the employees if we could just put a dimmable bulb in and be fine. They said we could, so we got a dimmable bulb to fit it.
So, is there any physical difference in the fixture between dimmable and "standard"? The reason I ask is that the light sometimes won't come on when we hit the switch. Sometimes sliding the dimmer makes it come on. And then there are times like just now where I hit the switch, it didn't come on, I played with the dimmer, still nothing. So I took the dogs out for a minute and when I came back in (~5 minutes) it was on!
What's going on here? Is this dangerous?
dismas is offline   Reply With Quote
Old 10-10-2010, 09:14 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Dimmable CFL
Not dangerous, not annoying. There are Dimming type CFL's, and they will say on the package if they are able to.
Old 10-10-2010, 09:17 AM   #3
I=E/R
a7ecorsair's Avatar
Dimmable CFL
From the title of this thread, it appears you are running a compact fluorescent lamp. Did you install this in an existing fixture or did you buy a new fixture too?
Here is your first mistake:
CFL, or any fluorescent, needs full voltage for the ballast to fire the bulb. As the directions state, they don't work on a dimmer.
a7ecorsair is offline   Reply With Quote
Old 10-10-2010, 09:18 AM   #4
Dimmable CFL
Yeah, we have a dimmable CFL in the fixture. Thanks, maybe I wasn't clear enough on that.
Old 10-10-2010, 09:20 AM   #5
Dimmable CFL
It is a new fixture. This new fixture says that it doesn't work with a dimmer switch. Since it includes a bulb, we were told that the fixture would be fine with a dimmer but the included bulb would not. So we got a new bulb that clearly says "dimmable" on it.
The previous fixture worked fine with a dimmable CFL bulb in it. This new one does not.
Old 10-10-2010, 09:58 AM   #6
Xtreme DIY'r
Dimmable CFL
If the fixture states it will not work with a dimmer switch then take the switch out
Or replace the fixture with one that will work with a dimmer
SPECIFIC CFL's can be dimmed - twisty bulbs that aree marked dimmable
Sometimes you need a certain dimmer to work with a CFL dimmable bulb
Old 10-17-2010, 09:13 AM   #7
Dimmable CFL
Just in case someone searches for CFL info and comes across this thread...
A previous respondent said that this set-up wasn't dangerous or annoying. They seem to be right about half of that. My house didn't burn down but it was rather annoying not having a light turn on when you wanted it to.
And apparently there is a difference in the fixtures between dimmable and non. It's not just the bulb that makes a set up dimmable.
I've replaced the dimmer switch and the dimmable bulb with a regular switch and regular CFL bulb. The light now works 100% of the time.
Unable to find out how to wire a dimmable light transformer Maleko Electrical 9 02-07-2010 02:07 AM
Help with: Dimmable Compact Florescent Bulbs millerz1897 Electrical 19 04-06-2009 06:44 AM
GFCI and dimmable halogen ceiling fan light reverend_maynard Electrical 3 11-25-2008 10:05 PM
Dining Room fixture dimmable? newski Electrical 5 01-04-2008 09:11 AM
