Dimensions/Options For 200 Amp Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2009, 08:02 PM   #1
Dimensions/Options for 200 Amp Panel?
Hello,
I am upgrading my service from 100 amps to 200 amps. Problem I am running into is that I have a water drain pipe from my sink running below my current panel (its about 4 inches out in front of panel and well below). The clearance I have from the top of my current panel to the pipe is currently ~31-32 inches. It seems like 200 amp panels are commonly 37 inches in height, which would require some significant plumbing work on my end.
Question for the group: Are there 200 amp panels that would fit this length of < 31"? If so, what manufacturer and where can I get one?
Thanks in advance.
mmr1234 is offline   Reply With Quote
Old 08-27-2009, 10:32 PM   #2
Electrical Contractor
kbsparky's Avatar
A 30 space Square D type QO 200 Amp panel is 30 inches tall. The 40 space panel is 34 inches tall. Both are 14Ĺ inches wide, and should fit in between two standard spaced studs.
You can get a 30 space, 40 circuit panel: QO13040M200 which uses the 30 inch enclosure.
The cheaper Homeline panels are taller, with the 30 space panel using the same 34" enclosure as the QO 40 space panel. The 40 space Homeline panel is a whopping 40 inches tall.
I'd go with the QO panels, if space is a premium.
-KB
Old 08-28-2009, 05:12 AM   #3
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Any reason why the new panel can't be moved up a few inches to accommodate the pipe?
If you can, it will be ok as long as the new breakers or main breaker isn't more than 6' or 6'7"(can't remember which) off the floor.
wirenut1110 is offline   Reply With Quote
Old 08-28-2009, 08:52 AM   #4
Licensed electrician
Rewards Points: 1,892
The correct dimension is 6' 7" to the center of the highest handle.
Old 08-28-2009, 12:00 PM   #5
First off, thanks for the replies. my panel is pretty much as high as it can go, looks like I am going to have to get the pipe moved down about 6 inches or so.
Tags
200 amp , panel
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
