Dimension/clearance For Receptacle Above Micro? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 11:00 PM   #1
dimension/clearance for receptacle above micro?
Is there a standard, code, or preference for locating the receptacle in the cabinet above a microhood?
ees789 is offline   Reply With Quote
Old 07-28-2012, 11:16 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
I go about 6 inches on center above the bottom of the cabinet, and a few inches from the side.
Old 07-28-2012, 11:25 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by jbfan View Post
I go about 6 inches on center above the bottom of the cabinet, and a few inches from the right side.
clarified for you
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbfan (07-28-2012), MisterZ (07-28-2012)
Old 07-29-2012, 01:33 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Make sure you run this on on delicated circuit as microhood instruction called for so just be aware on that part ( typically 20 amp circuit useally do it in most case )
And check the manufacter cut sheet but most case it will be offset to the right from the centre line.( or whatever you hit the stud then you will know where to hit) and svp use the old work box so it will look more neater.
Merci,
Marc
Old 07-29-2012, 05:33 PM   #5
thanks
Okay, 6" on center from bottom and a few from the side. Are those old work gang boxes made to just clamp to the drywall, no need to locate studs except to avoid, right?
Old 07-29-2012, 06:32 PM   #6
Rewards Points: 6,652
Correct. If you have a stud to just the right or left of the cut, use a "Smart box", which has two wood screws inside the box, to attach it to the wood framing member.
Old 07-29-2012, 10:53 PM   #7
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No. Just mount a 1900 box in the vacinity of where the cord enters the cabinet. Bring the cable into the back of the box and mount the box over where the cable enters the cabinet. Then install a raised cover and your done. GFI not required.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
dishwasher, disposal and OTR Micro circuits rasz Electrical 29 08-24-2011 08:47 PM
micro amp thermostat okrite HVAC 3 04-03-2010 10:46 PM
Adding micro in older home zombie911 Electrical 5 04-30-2009 09:24 AM
Over the Range Micro cibula11 Electrical 8 04-22-2008 12:24 PM
Seesnake micro That one Guy Tools 1 05-26-2007 10:24 PM
